Thread: New headlight help
Results 1 to 5 of 5
  1. #1 New headlight help
    NW Indiana
    Well its time to get rid of the stock headlights, cant stand the haze anymore and it would be nice to see the road at night again. Anyone have any luck with the projector headlights as far as quality and price go? any help would be appreciated, Thanks.
  2. #2 Re: New headlight help
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    ebay has some good ones.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: New headlight help
    NW Indiana
    Ill check it out, thanks.
  4. #4 Re: New headlight help
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    There are two projectors available for our cars. The Spyder Auto ones are pretty good. They vibrate on some cars (so do stock headlights), but there are threads on how to fix that. Light output is significantly better that stock housings, even with halogen bulbs.
    I'd avoid the other projectors (easily identified by the 6 LED's in the corner). These use a H3 projector, and the beam pattern is as bad as stock or worse.
    Get these (Spyder Auto projectors):
    Not these:
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  5. #5 Re: New headlight help
    NW Indiana
    Thanks for the help, alot of good info. Those are some nice projectors, I dont like all the led chrome ones, too much going on.
  1. Need HID Headlight help
    By TooMch in forum Audio, Security & Visual Electronics
    Last Post: 11-06-2009, 11:37 AM
  2. DRL headlight help..
    By singularity in forum Audio, Security & Visual Electronics
    Last Post: 09-02-2009, 02:29 AM
  3. Headlight
    By gptrell502 in forum Visual/Body Modifications
    Last Post: 03-20-2009, 09:49 PM
  4. Headlight Install
    By 04gpking85 in forum General Tech Discussion
    Last Post: 11-17-2008, 11:57 PM
