Thread: Headlight bulbs? Whats the best/ most bright?
Results 1 to 18 of 18
  1. #1 Headlight bulbs? Whats the best/ most bright?
    SE Level Member 87GN97GTP's Avatar
    Westminster, MD
    Well I ordered my ebay black headlights yesterday to replace my busted and ugly stockers and I figure I should go ahead and put some new bulbs in while I'm at it. I want bright and clean, no blue rice looking bulbs just bright clear clean white. What do you guys run? We have 9007's right? TIA -Adam
    97' Grand Prix GTP 2 door
    87' Buick Grand National
    84' Buick T Type
    78' Buick Sport Coupe
  2. #2 Re: Headlight bulbs? Whats the best/ most bright?
    Donating Users
    Plainfield, IL
    GET HIDS fukk halogens
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  3. #3 Re: Headlight bulbs? Whats the best/ most bright?
    silverstars!
  4. #4 Re: Headlight bulbs? Whats the best/ most bright?
    Westminster, MD
    Quote Originally Posted by gotboost3 View Post
    I just got new housings so I want to stick with halogens I just want bright bulbs.
    Quote Originally Posted by boosting98 View Post
    silverstars!
    Looked at them.......
    What about these?????? Are they good do they work OK????
    SUPER White HID Xenon Look Headlights 9007 90/100W:eBay Motors (item 200347240672 end time May-31-09 17:01:54 PDT)
    84' Buick T Type
  5. #5 Re: Headlight bulbs? Whats the best/ most bright?
    memphis
    I agree about tha silverstars..i had a set in my strat..they where super bright.
    I got a set ebay 8000k bulbs in my buick now..i got them cause they fit tha blue theme i'm doing.They a brighter than i thought, Plus they where only like $10. they've have lasted 4 months & for that price i can't complain..
  6. #6 Re: Headlight bulbs? Whats the best/ most bright?
    Aug 2008
    KCMO
    Piaa's
  7. #7 Re: Headlight bulbs? Whats the best/ most bright?
    Dec 2008
    Lawndale, CA
    If you stay with halogens look into the following options besides silverstars. With PIAA's your paying for the name. GE Nighthawks and Philips Xtreme power. They will appear a little more yellow than silverstars but they have a clear glass lens and maximum lumen output. The bluish colored glass limits light output.
  8. #8 Re: Headlight bulbs? Whats the best/ most bright?
    Westminster, MD
    Thanks for the input guys
    84' Buick T Type
  9. #9 Re: Headlight bulbs? Whats the best/ most bright?
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    What did you go with?
  10. #10 Re: Headlight bulbs? Whats the best/ most bright?
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    i had a pair of phillips Xtreme power, and they were very bright. Look into a 9007 relay harness also, gives your bulbs more volts, resulting in a brighter and whiter light. This is the relay harness i use, and can also splice hids into it very easy.]
    9004 9007 Complete Head Lamp Wiring with Relay System Kit
  11. #11 Re: Headlight bulbs? Whats the best/ most bright?
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    Quote Originally Posted by 87GN97GTP View Post
    I wouldn't recommend them. It's not a question of if you'll damage something; it's a question of whether the wiring or the housing will go first.
    Adding a relay harness is the most noticeable way to get brighter light form halogen bulbs. The brightest 9007 bulb you're going to find is the Philips X-treme Power.
    Avoid the blue tinted bulbs. The blue tint filters out light, which will never make the bulb brighter. The Sylvania SilverStars use a hotter burning filament, which produces more light (making them as bright through the blue tint as a regular un-tinted bulb) but shortens the bulb life.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  12. #12 Re: Headlight bulbs? Whats the best/ most bright?
    Apr 2009
    stockton ca
    These melted my wiring and started to melt my lenses in my beater neon i had
  13. #13 Re: Headlight bulbs? Whats the best/ most bright?
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    i have silverstar Ultra's and they are great, though i have silverstar headlights, fogs, and signals...ran me $125
  14. #14 Re: Headlight bulbs? Whats the best/ most bright?
    Flint, Michigan
    Forget all those...If you use a 9005 or 9006 bulb go to your John Deere dealership and get some HIR bulbs (Halogen Infrared)
    HIR Headlights 9011 9012 bulbs read up on these
    https://jdparts.deere.com/servlet/co...umber=AH211917
    John Deere they are only about $14.00 each for 75% more light output!
    I was ensured that the price was for a pair...In fact it was for a single...John Deere must be catching on to this trick.
  15. #15 Re: Headlight bulbs? Whats the best/ most bright?
    Apr 2009
    Quote Originally Posted by BryanB View Post
    So the 211917 you mention here is the bulb to replace ours? If so, I'll just call and have them put a set aside for me.
  16. #16 Re: Headlight bulbs? Whats the best/ most bright?
    Flint, Michigan
    the John Deere part number is ALMOST a 9006 bulb. You remove about 3mm of plastic from them...a nail clippers does the job nicely...and they'll go right in!
  17. #17 Re: Headlight bulbs? Whats the best/ most bright?
    Apr 2009
    Aren't our bulbs a 9007 p/n? I'm talking '97-'03
  18. #18 Re: Headlight bulbs? Whats the best/ most bright?
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by SnowDrift View Post
    HIR bulbs do not come in 9007. So you don't need to worry about those. The 04+ people can use them as well as those who use the projectors on 97-03's. As stated any bulb that does not have a blue coating is a good bulb. Nighthawks and philips xtreme power are nice choices. You can run a relay harness to have the battery powering the bulbs instead of the factory wiring. Silverstars have a blue coating and tend to burn up quickly due to sylvania having the filiment burn hotter. If you decide to run high wattage clear bulbs then definitely get a relay harness, or your wires may melt. This is if you want to stick with halogens.
  1. 9007 bulbs
    By Slueth66 in forum Visual/Body Modifications
    Last Post: 02-17-2009, 04:33 PM
  2. Dic Bulbs
    By J_Ferguson in forum General Tech Discussion
    Last Post: 10-21-2008, 06:07 PM
  3. i need bulbs
    By bb52190 in forum Off Topic Discussion
    Last Post: 08-24-2008, 02:40 PM
  4. Fog bulbs
    By Tig in forum Visual/Body Modifications
    Last Post: 05-17-2008, 02:07 PM
  5. fog bulbs
    By Toasty in forum General Tech Discussion
    Last Post: 03-26-2008, 10:23 PM
