Thread: Remove Headlamp assembly?
Results 1 to 2 of 2
roboz Remove Headlamp assembly? 04-14-2009, 01:03 AM
roboz Re: Remove Headlamp assembly? 04-15-2009, 08:01 PM
  1. #1 Remove Headlamp assembly?
    Jul 2008
    i have 1996 4dr SE 3100
    I was wondering how exactly to remove the headlamp assembly, or if there is a way to get to the 194 sized axillary bulbs within the headlamp, i had a few ideas with LEDs as well as some other modifications and restoring the lamps.
    I also found a neat link for DIY halo lights i may look into on youtube. I haven't been able to find a writeup about this, or it is more simple than i realize.
    An idea i had for my headlamps is replace the not so bright glowing auxiliary bulbs inside the headlamps with UV 194 bulbs of some sort. There is a special spray paint that is sprayed clear but reacts to ultra violet light and i thought this could look pretty unique having the headlight cover glowing if done right
    thanks in advance
    -Rob
  2. #2 Re: Remove Headlamp assembly?
    Jul 2008
    i realized there are just 2 bolts behind the assembly holding the lamps down...
  1. Headlamp adjuster fix: [*]
    By BackInBlack in forum How To Write-Ups/Tech Tips
    Last Post: 05-12-2015, 09:31 PM
  2. 98 GP stock air filter assembly
    By hacket in forum General Tech Discussion
    Last Post: 03-24-2009, 10:50 PM
  3. Steering issues... hub assembly?
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 05-18-2008, 09:25 PM
