Thread: removing the Third Brake light
Results 1 to 14 of 14
  1. #1 removing the Third Brake light
    GT Level Member cojo's Avatar
    Flint Michigan
    Ok I just bought a grand prix decal that goes over the third brake light. But I dont quite know how to remove the 3rd brake light so I can apply it...
    help would be greatly appreciated
    thanks
  2. #2 Re: removing the Third Brake light
    you have to take it apart from the trunk. it is kind of a pain in the ass.
  3. #3 Re: removing the Third Brake light
    Flint Michigan
    ok I thought so, are the bolts easy to find??
  4. #4 Re: removing the Third Brake light
    Flint Michigan
    does it have anything to do with the orange tabs?
  5. #5 Re: removing the Third Brake light
    Nov 2008
    Chicago
    you can also take the rear seats and rear deck out. even more of a pain in the ass though
    Last edited by FuglyGTP; 03-14-2009 at 01:13 AM. Reason: Hey whaddya know?! its my 200th post!
  6. #6 Re: removing the Third Brake light
    Flint Michigan
    ok thanks, so do the orange tabs have anything to do with it???
  7. #7 Re: removing the Third Brake light
    im not quite sure, maybe someone else can chime in here. i have never taken mine apart.
  8. #8 Re: removing the Third Brake light
    Flint Michigan
    ok thanks for the help though. That vent piece is were change the bulbs, so thats why im thinking the orange tabs have something to do with it.
  9. #9 Re: removing the Third Brake light
    Moore, Oklahoma
    You have to pull your back seat and your package shelf from inside the car to remove it, trust me I know. I installed a GTP overlay over my 3rd brake light...
    Shawn W. Larsen
  10. #10 Re: removing the Third Brake light
    Flint Michigan
    Quote Originally Posted by Iron Indian View Post
    Thanks, do you think you could be more descriptive how to remove the package shelf??? I would really apprecaite it.
  11. #11 Re: removing the Third Brake light
    Moore, Oklahoma
    Its been awhile but...
    Back seat is held on with some tabs on the bottom section, pull out tabs and move up seat on both sides, back seat bottom can be removed. For the seat top, remove a couple bolts and its hooked in. Seat should pull up and out with the seat belts. From there you should see how to take out the seat belts pass through from there it SHOULD pull out. The brake light should slide out too.
    Its been 5 years amd thats to the best of my memory....
    Shawn W. Larsen
  12. #12 Re: removing the Third Brake light
    Donating Users RedLedbetter's Avatar
    Feb 2009
    Illinois
    thats correct. i found that its easier to take the top shelf if you pull out one side all the way and then let the thing just pull out.
    SPREAD THE JAM
  13. #13 Re: removing the Third Brake light
    Flint Michigan
    thanks alot!!! ill post back if I have any problems when I try it this weekend.
  14. #14 Re: removing the Third Brake light
    Flint Michigan
    ok gonne try this weekend thanks
  1. 4th Brake Light (Under Decklid)
    By drunknmunky in forum How To Write-Ups/Tech Tips
    Last Post: 05-27-2011, 07:57 PM
  2. Tips on Removing Brake Lines
    By JoshMcMadMac in forum Brakes/Suspension/Chassis
    Last Post: 08-16-2008, 08:45 AM
  3. 4th Brake Light/Write Up
    By drunknmunky in forum Visual/Body Modifications
    Last Post: 07-26-2008, 06:37 PM
  4. parking brake light???
    By kingd44 in forum General Tech Discussion
    Last Post: 02-20-2008, 11:38 PM
