Thread: Spyder Headlight Retrofit/Redesign
Results 1 to 20 of 23
  1. #1 Re: Spyder Headlight Retrofit/Redesign
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Quote Originally Posted by Bronco Boy View Post
    I've had good success with the 2 part plastic bonders. The last one I used was JB Weld.
    Plastic Bonder Syringe
    | J-B Weld
    Thanks bronco! I actually decided to be brave and try plastic welding for the first time! Bought a cheapo from harbor freight for $15, and cut some polypropylene from the stock airbox I had lying around which was nice and thick. Used the mesh that came with the kit to reinforce the weld. It's stronger than the entire tab now! I might have to go back and add some braces to the bracket since I can literally weld to almost anywhere on the headlight. Not the best looking solution, but it works!
    Tomorrow, I'll re-wire the harnesses so I can test them out of the housing and point them in. Once I have a baseline for what angle they need to be in, I can finish modifying the housing to make them work and re-seal them finally!
  2. #2 Re: Spyder Headlight Retrofit/Redesign
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by wstefan20 View Post
    Nice.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Retrofit headlight install
    By Aloeffler97 in forum General Grand Prix Discussion
    Last Post: 10-05-2016, 10:22 PM
  2. Spyder Headlight help?
    By Sulvestr in forum Visual/Body Modifications
    Last Post: 03-25-2015, 03:34 PM
  3. Spyder Headlight Conversions
    By Frank1 in forum Introductions/Noob Questions
    Last Post: 01-17-2015, 07:06 AM
  4. Spyder Halo Headlight question
    Last Post: 07-01-2013, 09:55 AM
  5. Spyder headlight
    By shawnschuldt in forum Visual/Body Modifications
    Last Post: 07-13-2011, 10:55 AM
