Thread: A different HID projector thread/question - help
Results 1 to 7 of 7
LeadfootCJ7 A different HID projector... 03-22-2018, 08:04 AM
wstefan20 Re: A different HID projector... 03-22-2018, 08:55 AM
LeadfootCJ7 Re: A different HID projector... 03-22-2018, 09:48 AM
wstefan20 Re: A different HID projector... 03-22-2018, 10:03 AM
Bronco Boy Re: A different HID projector... 03-22-2018, 11:46 AM
LeadfootCJ7 Re: A different HID projector... 03-27-2018, 05:11 PM
wstefan20 Re: A different HID projector... 03-27-2018, 09:15 PM
  1. #1 A different HID projector thread/question - help
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Ok, I have had TRS HID projectors in my headlights for about 4 years. They have been good except the ballast randomly not firing, but that's another story for another day. One of my headlight assemblies was damaged recently to the point the housing is garbage. Is it possible to remove the projector and use it to build another headlight or do I need to start over? I know I could attempt it, but I am trying to plan ahead and limit downtime. Just wondering if anyone has experience at this or has attempted it. Any advice?
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  2. #2 Re: A different HID projector thread/question - help
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Quote Originally Posted by LeadfootCJ7 View Post
    Possible? Yes, practical? No. The projectors that come in those are pretty poor in quality compared to say morimoto retrofits. you'd have to cut the projector out, mark on the new headlight, dremel the back out to fit it, then use jb weld all over, pray you pointed it correctly, hope you can find a shroud to fit, then hope it doesn't leak! Granted, it may not look quite as cool.
    Personally, I'm a fan of the retrofits. They're better made projectors, and they're brighter to boot!
  3. #3 Re: A different HID projector thread/question - help
    Oct 2012
    Houston, TX
    Mine are Morimoto. I bought them from TRS. I did the retrofit myself. (I probably wasn't clear on that in the first post) I tried to use plenty of JB weld to hold them in which is why I am concerned about being able to remove them without destroying them.
  4. #4 Re: A different HID projector thread/question - help
    Aug 2017
    Raytown, MO
    Haha didn't recognise your abbreviation there! Thought you were referring to the spyder projectors!
    But yes, I've done it before no problem. I use a dremel wheel to cut them out and carefully sand them down. I'm not saying it's easy, just possible.
  5. #5 Re: A different HID projector thread/question - help
    Jul 2010
    Coquitlam,BC,Canada
    Can be done. The only problem I see is grinding away all the old JB Weld. It just sounds like fun. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: A different HID projector thread/question - help
    Oct 2012
    Houston, TX
    I am def not excited about trying this. Time is certainly a concern because I won't have lights and can't drive the car while I am doing this.
  7. #7 Re: A different HID projector thread/question - help
    Aug 2017
    Raytown, MO
    Good luck! It's not as bad as you think one you get into it.
  1. Projector/Halo question
    By 2001GPGTP in forum Introductions/Noob Questions
    Last Post: 05-02-2013, 01:59 PM
  2. Projector headlights question
    By szalajka05 in forum General Tech Discussion
    Last Post: 04-11-2012, 06:59 AM
  3. Is their a good DIY Projector/HID thread?
    By h0wl0ngcanitbe in forum Audio, Security & Visual Electronics
    Last Post: 01-12-2011, 12:59 AM
  4. Projector Question??????
    By silvermistgt2002 in forum Visual/Body Modifications
    Last Post: 08-13-2009, 09:56 PM
  5. projector headlight question
    By superv6 in forum General Tech Discussion
    Last Post: 08-06-2009, 01:41 AM
