wstefan20
Just removed these to swap the cloth panel with leather. Pretty easy, and there's probably more ways than one to do it. The problem is that they put a clip connecting the upper door pillar trim attached to this panel near the rear, which means you need to remove this first.
1. pop open seat belt bolt cover using T45 bit and remove seat belt anchor.
2. remove light by *gently* poping cover off (clips on each side) like you are removing the bulb, removing both Phillips screws to remove light bracket, and finally pinching on either side of inner bulb socket to release bulb from holder.
3. remove "clothing hook" by pulling the center part out and removing clip
4. now just "tug" on the pillar to remove and pull forward
Now that that is out of the way, I'll have to double check, but I think you can just pull on the panel to remove. I say I'll have to check because I had the rear seat out as well to do this so I'm not sure if that interferes or not...
If you can wait till the weekend, I'll try to find the time to try this at the junkyard (don't want to have to do this again on mine), shoot some pics, and post a write-up.
Hope this helps! Good luck
