Thread: Cut outs: about how much should they cost?
Results 1 to 12 of 12
  1. #1 Cut outs: about how much should they cost?
    May 2015
    Maryland
    About how much should cut outs cost?https://www.youtube.com/watch?v=EGriXRQXOMs
    Matt
  2. #2 Re: Cut outs: about how much should they cost?
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Depends on how good you are at fabricating just the electronic cut out on the exhaust I've found cheap as $60 but that's no pipe or anything or the most expensive kit I've seen is everything you need to install it and bam done was $149.99. It all depends on what you want to do and how good you are at fabricating your own stuff.
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  3. #3 Re: Cut outs: about how much should they cost?
    Depends on what brand and if it's a manual cut out or a electronic unit.
    You'll have to do some research on it.
  4. #4 Re: Cut outs: about how much should they cost?
    GXP Level Member
    Mar 2015
    Tomball
    You'll spend between 60-200 for the cutout itself. I've been looking at a vacuum actuated unit it's $155 which is more than most of the electrically actuated ones. Then you have to put it in. No idea on the cost there.
  5. #5 Re: Cut outs: about how much should they cost?
    May 2015
    Maryland
    You guys have any links on where to purchase kits?
    Matt
  6. #6 Re: Cut outs: about how much should they cost?
    Jan 2013
    leavenworth ks
    Oh here's the controls to that last one.221710452113
  7. #7 Re: Cut outs: about how much should they cost?
    Jan 2013
    leavenworth ks
    EBay number 170628327035. 121870256460.371313335110.
  8. #8 Re: Cut outs: about how much should they cost?
    Kemmerer, Wyoming
    are those kits any good? I've been considering a cutout, but haven't pulled the trigger because I've heard about quality and longevity issues.
  9. #9 Re: Cut outs: about how much should they cost?
    Jan 2013
    leavenworth ks
    It's up to you really just eBay electronic exhaust cut out. This is a kit I've been looking at its in mid range on price so I don't feel like I'm paying for crap and I looks okay. 272115274841
  10. #10 Re: Cut outs: about how much should they cost?
    hangover park IL
    just bolt an 04+ drive-by-wire throttle body to the exhaust and wire directly to the servo motor. boom free electric cut out
    ~James~ Psychotic Gearhead
  11. #11 Re: Cut outs: about how much should they cost?
    May 2015
    Maryland
    Thanks Travis. I'll check those out.
    Matt
  12. #12 Re: Cut outs: about how much should they cost?
    Jan 2013
    leavenworth ks
    No problem
  1. Replies: 10
    Last Post: 07-24-2015, 08:54 AM
  2. Rockauto close outs
    By BillBoost37 in forum Off Topic Discussion
    Last Post: 02-10-2011, 01:17 PM
  3. For those of you who have done part-outs....
    By SliceTheRice in forum General Tech Discussion
    Last Post: 07-12-2010, 11:45 PM
  4. SHOUT OUTS to PONTIAC
    Last Post: 10-29-2008, 11:54 PM
  5. looking for pics of exhaust cut-outs
    By fst in forum Visual/Body Modifications
    Last Post: 01-04-2008, 04:57 PM
