Thread: Double roller timing chain machining?
Results 1 to 12 of 12
  1. #1 Double roller timing chain machining?
    SE Level Member Loftus1995's Avatar
    Jun 2014
    United States
    I have been told that the gear on the crank shaft has to be machined a little? Can anyone give insight on this to what needs to be taken off?? The photo isnt mine but just a little confused on what I need to get taken off.
    On a sife topic anyone have an hp tuner for sale?? want to learn how to tune my car.
    Sent from my SM-G900P using Tapatalk
  2. #2 Re: Double roller timing chain machining?
    Nov 2011
    NY
    You should make a want to buy thread separately... May get an answer that way for tuner.
    as for the Double Roller, use the search function, there is major threads on this subject. Not sure another one is necessary! Basically, take the double roller crank gear and the stock to a machine shop and have them matched!
    good luck
  3. #3 Re: Double roller timing chain machining?
    I break stuff selliott's Avatar
    Kansas City
    ^^this cost me $20 and 15 min to have mine machined
  4. #4 Re: Double roller timing chain machining?
    Jun 2014
    United States
    Ok it looks like more the teeth need to be more rounded from what I could see ill have to look into it before I take it in tomorrow
  5. #5 Re: Double roller timing chain machining?
    Kansas City
    the chamfer needs to be machined
  6. #6 Re: Double roller timing chain machining?
    Antioch, IL
    2009 Challenger SRT8
    Expert at being gay.
  7. #7 Re: Double roller timing chain machining?
    Jun 2014
    United States
    Ok so the first one is the stock, then the second is the double roller. Am i looking at getting that more edged part in the middle? From what i was reading it just wasn't flush against the block on the crank so it would rub??
  8. #8 Re: Double roller timing chain machining?
    Antioch, IL
    yes, bring both gears in to the shop and say make this like this.
  9. #9 Re: Double roller timing chain machining?
    Kansas City
    Quote Originally Posted by ITHURTZ View Post
    this
  10. #10 Re: Double roller timing chain machining?
    Jun 2014
    United States
    I took it in told them I needed it chamfered and they knew exactly what I was talking about! Thanks guys.
  11. #11 Re: Double roller timing chain machining?
    Jun 2014
    United States
    I got a little excited before taking the gear in and already had the gasket put on. Its mostly in tact except for the bottom where a little of the paper tore off with the front cover. Should I replace it? If so could I double up on a stock gasket or wait the weekend to get the extra thick one from zzp.
  12. #12 Re: Double roller timing chain machining?
    Buffalo
    Get your oil pump cover machined and run a single metal gasket
  1. Rollmaster Double roller timing chain
    By SgtMarshal in forum For Sale - Parts
    Last Post: 12-01-2014, 12:10 PM
  2. double roller timing chain
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2013, 06:47 PM
  3. help me with a double roller timing chain
    By foursixer in forum General Tech Discussion
    Last Post: 12-20-2010, 12:20 PM
