Thread: turbo info
Results 1 to 20 of 22
  1. #1 turbo info
    GT Level Member sdenton8's Avatar
    marshalltown, iowa
    Im not 100% sure on how to read compressor maps. So ill see if I can get some help. I want to find out what would be a good turbo for a daily driven street car? Not going for crazy numbers. Maybe between 300-350whp
  2. #2 Re: turbo info
    GTP Level Member
    Jan 2015
    Lincoln, NE
    i would go with a t4 frame with a low 60mm compressor size. something like a 60-1 62-1 or T61. borg warner, precision, etc. personal opinion is to stay away from turbonetics.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  3. #3 Re: turbo info
    marshalltown, iowa
    So your talking about a straight t4 turbo? No hybrid like a t3t4? Probably would be to small.
  4. #4 Re: turbo info
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by sdenton8 View Post
    t3 turbine is too small for the 3800
  5. #5 Re: turbo info
    SE Level Member SlowFiero's Avatar
    Feb 2008
    Canada
    <------- Uses t3 turbine housing, works just fine.
    I would go with a precision 5858 or 6262. 6262 will have room to grow. T3 housing will spool quicker, t4 housing will be marginally easier on trans as boost will be slightly slower coming in. Either will support far more than your current goal.
    Billet 6262 T3 turbo, PT1001 intercooler, ST1 cam, 140 springs, pushrods, N* TB, L26 upper, HV3, otherwise stock L32. 10.007 @ 135.54with 1.46 60' 3130 lbs
    Old GenV M90, XP, heads, N* TB, ST2 intercooler - 11.425@115.60 1.54 60'
  6. #6 Re: turbo info
    GTP Level Member
    Jan 2015
    Lincoln, NE
    t3 in what a/r and what diameter turbine wheel and trim? if cost isnt an issue either of those would be great choices.
    any idea how much power your car made on 18psi?
  7. #7 Re: turbo info
    Feb 2008
    Canada
    .63 ar. 62mm exducer.
    These new turbos are a definate step above the old 60-1, pt62 etc of old. There would be more back pressure on a older unit I suspect. And the compressors just move more air now.
    Not sure on power, only time I had it on dyno I had fuel pressure issues. Made 465 rwhp on 15lbs on a mustang dyno misfiring and knocking from being lean. Could feel the misses in the car.
    Hp calculators put 3130lbs at 580-590 hp for 134.44 mph. That would be dynojet hp. I'd expect low-mid 500 rwhp on a mustang, and it pulls even harder at 24psi lol. Finally have a trans to put up with the power, but my converter I had built was eating around 80hp last summer. Lost 8mph at same boost over the Zzp 3250 I was running on the 134 mph pass. Precision cut the converter back apart, said they knew what they missed on the first time, so we will see. Hoping for easy 9s and closer to 140mph this summer.
  8. #8 Re: turbo info
    damn that's hauling ass in a fiero!
  9. #9 Re: turbo info
    Feb 2008
    Canada
    Thanks.
  10. #10 Re: turbo info
    marshalltown, iowa
    Its a 73 trim turbine .63 ar
    in is 65.5
    Ex is 55.9
  11. #11 Re: turbo info
    marshalltown, iowa
    I just know the turbo is a t3t4 ar .63 turbine with .57ar compressor.
  12. #12 Re: turbo info
    GTP Level Member
    Jan 2015
    Lincoln, NE
    what is the inducer size of the compressor?
  13. #13 Re: turbo info
    hangover park IL
    the TR has .82 AR T3 exh with 70mm inducer compressor side.
    dont hold me to it but i believe our turbine is 65mm
    on my WaGN im using something quite similar (70mm compressor, Q exhaust) but with the buick turbine housing and not the std t3 stuffs.
    it amazing the kinda crap im doing to make this look like a "regular" LC2 turbo buick drivetrain swap but with all FWD 3800 stuff rofl
    ~James~ Psychotic Gearhead
  14. #14 Re: turbo info
    marshalltown, iowa
    Thats the only measurement I could find
  15. #15 Re: turbo info
    GTP Level Member
    Jan 2015
    Lincoln, NE
    if its a .57a/r compressor it should be a t04b cover. it will work but probably wont be optimal. still more efficient then the m90. its just hard to say without knowing the compressor size as that housing could be used on everything from 40 to 57mm
  16. #16 Re: turbo info
    Nov 2012
    Erlanger, KY
    Low HP expectations with a turbo setup..
    Even with the T4 T67 .68ar mutt turbo from ZZP/Stattama and ST5 cam, lag was very minimal. Drove fine on some 200+ mile trips,
    and around town, on the highway, ect. Perfect to me for daily driving it seemed.
    No idea what your budget is.. or if will change up plans later.. or preference in turbos. New/used/china whatever, time frame, ect. but..
    Can always keep an eye out @ http://shop.precisionturbo.net/index...ochargers.html
    Can sometimes score a decent deal on a new or refurb unit.
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  17. #17 Re: turbo info
    Kemmerer, Wyoming
    just out of curiousity, what turbo would you guys say would be good for a car that has an xp cam and will be using the supercharger housing with a blockoff plate and air to water intercooler?
  18. #18 Re: turbo info
    GTP Level Member
    Jan 2015
    Lincoln, NE
    if money isnt an issue the 6262 cea from precision is a good choice and should support 500+ WHP. i wouldnt sub that air to water for a good front mount though.
  19. #19 Re: turbo info
    Kemmerer, Wyoming
    my transmission is only good for 400 hp, so that is the goal at this point.
  20. #20 Re: turbo info
    GTP Level Member
    Jan 2015
    Lincoln, NE
    dont turn it up over 14psi then.
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2024, 11:56 PM
  2. first days!!! any info of good info
    By 97gtp83boy in forum Introductions/Noob Questions
    Last Post: 02-24-2013, 02:17 AM
  3. turbo info
    By sdenton8 in forum Turbo
    Last Post: 06-16-2012, 12:06 PM
  4. Need Some Turbo Info Here
    By GMR Badass in forum Turbo
    Last Post: 06-08-2012, 11:19 AM
  5. Need some turbo info.
    By TDCRacing in forum Turbo
    Last Post: 01-27-2009, 07:12 AM
