Thread: New P&P Heads
Results 1 to 11 of 11
  1. #1 New P&P Heads
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Well just a quick little update. Back in Nov. I blew my head gaskets at the track. Took ZZP stg 2 heads off and got them tested before putting new head gaskets on.. Both were cracked and are no good. Probably happen when I ran my 10.9 and ran super lean at +18 on wideband. Head gaskets most likely blew due to my engine not being able to breathe.
    Was able to get a set of L32 heads from Steve Chesser.
    Then sent them to Chris Hinson.
    He's on Facebook. Don't think he is on here.
    His FB page is Bully-Flo Racing Heads
    Heads came out amazing. I paid him to go all out. Even did a 3 and 5 angle valve job.
    He guesstimates my heads to flow 215 CFM intake @550 and 240+ @600
    Here are pics.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  2. #2 Re: New P&P Heads
    Feb 2014
    Ky
    How much? If you don't mind my asking?
  3. #3 Re: New P&P Heads
    Feb 2008
    NY
    Quote Originally Posted by ugot8up01 View Post
    Cost depends on what you want done.
    I had him do the angle job which cost more and I also had him assemble the heads with the springs, seals, etc.
    His FB page is Bully-Flo Racing Heads.
  4. #4 Re: New P&P Heads
    Aug 2013
    McDonald PA
    Chris is orangel67 on her iirc
  5. #5 Re: New P&P Heads
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    Not to be negative nancy but do those exhaust ports differ in size head to head or is that just the picture?
    Email all inquiries to willoverkill@gmail.com!
  6. #6 Re: New P&P Heads
    Feb 2008
    NY
    You are correct. I just look it up
  7. #7 Re: New P&P Heads
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    Quote Originally Posted by Overkill View Post
    I see it too, even the shapes look different
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  8. #8 Re: New P&P Heads
    Feb 2008
    NY
    If you look at the exhaust ports on my ZZP stg2 heads and Chris' heads there is a big difference.
  9. #9 Re: New P&P Heads
    Banned
    CT
    This.
    I've been begging to see flow bench numbers. Wish someone would do it, especially next to a set of zzp heads.
  10. #10 Re: New P&P Heads
    Kemmerer, Wyoming
    flow benches cost money, I think Chris did flow a set one time, but I dont remember what he said.
  11. #11 Re: New P&P Heads
    The Boss Iceman6669's Avatar
    Jun 2011
    OP I cleaned the thread up. Lets keep it on topic, if you wanna have a pis*ing match go to the Rant section or FFA.
    2011 F-150 Yote powered
  1. Help on crack heads..need advice on l26 heads
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2013, 10:07 AM
  2. ZZP Heads VS Intense Heads
    By PurpleGuy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 07:57 AM
  3. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
