Thread: Turbo Project- Posting throughout the entire build
Results 41 to 60 of 61
  1. #41 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by Loftus1995 View Post
    I was thinking new pistons, zzp is a little pricey but if I can get them soon I may get a set
    it would be cheaper to just call morad and get a L67 short block shipped to you.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  2. #42 Re: Turbo Project- Posting throughout the entire build
    SE Level Member Loftus1995's Avatar
    Jun 2014
    United States
    With the short blocks everything would line up, wouldnt have to do anything rather than putting it all back together
  3. #43 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    yeah just pull the N/a heads off your engine and have them planed and install them on the new short block. if you get an engine with a steel oil pan you dont have to swap that either. if its aluminum you can either clearance the motor mounts or install a steel oil pan. install your N/a intake on the motor and you are done. the only other thing that i swapped was the harmonic balancer. all your accessories on your stock motor should bolt up. that will give you 8.5 to 1 compression and a way stronger bottom end. and its a lot easier to do the valve train upgrades with the heads off.
  4. #44 Re: Turbo Project- Posting throughout the entire build
    Jan 2015
    Michigan
    i know nothing about this i just wanna get notifications when someone posts here
  5. #45 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    The ls7 lifters, atleast it says it pairs well with 60 through 105 springs. What springs do you run neb? Im going to upgrade my rods it sounds like if I get new lifters
  6. #46 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    i run the LS7 lifters with 130# springs.
  7. #47 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    your push rods? why?
  8. #48 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    I really just dont want anything to break
  9. #49 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    only reason to change them is if the stockers arent the right length.
  10. #50 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    and the only reason to change the lifters out is if they're bad
  11. #51 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    Quote Originally Posted by NebTurboST5 View Post
    I searched for Morad and he hasn't been active in almost five years. Is there an official website I can go to, to check prices?
  12. #52 Re: Turbo Project- Posting throughout the entire build
    search ebay. they have a store there. and morads.com works iirc to get to the home web site.
  13. #53 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    That website didn't work but I did look at their ebay listings and nothing came up. I did message them though, I will have to check tomorrow.
  14. #54 Re: Turbo Project- Posting throughout the entire build
    May 2008
    Schuyler, NE
    You're best bet is to email him. His eBay prices are pretty high.
  15. #55 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    Well I just googled morads and found kind of like a junk yard website it looked like. How you choose your vehicle make and all. I messaged them through there.
  16. #56 Re: Turbo Project- Posting throughout the entire build
  17. #57 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    complete L67 pullouts for 540...wish i would have gotten my L32 for that back in the day.
  18. #58 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    He said they have a long block for 350 but when I said I needed a shortblock he said he could take the heads off and sell it to me for 250. If there is nothing that has to be done to the block I may use my extra. I have a supercharged l67 motor out of another car already could I just use that one instead of spending an extra $300
  19. #59 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    that would make sense
  20. #60 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    Is there any extra milling that you know of that has to be done? Or is it just stronger pistons and all in the l67? I can get the block done tonighy if needed then
  1. Grand prix project build
    By forcedinduction in forum Introductions/Noob Questions
    Last Post: 06-04-2013, 09:17 PM
  2. Project Z38. Fosho99/Nvsridez Build
    By nvsridez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2013, 07:52 PM
  3. project build
    By 98buicksupercharged in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2012, 03:06 PM
  4. Project 91 Firebird Build Thread
    By Lsick7 in forum Off Topic Discussion
    Last Post: 07-12-2010, 02:31 PM
  5. The new guy: Matto's Project build thread!
    By Matto211 in forum General Tech Discussion
    Last Post: 01-10-2009, 07:47 PM
