Thread: Boost Gauge Tap
Results 1 to 11 of 11
  1. #1 Boost Gauge Tap
    SE Level Member chibiblacksheep's Avatar
    Southeast, PA
    My Monte Carlo isn't a turbo'd car, but my CSC set-up is basically just like a belt driven turbo.
    What would be the best line to run my boost gauge? Every time I search for it online, I keep finding threads for the L67 and using the BBV which I do not have.
  2. #2 Re: Boost Gauge Tap
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Dude that setup looks sick, wish I could answer your question tho.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: Boost Gauge Tap
    Southeast, PA
    Haha thank you. Still working like crazy on this build. Tuning has been a nightmare.
  4. #4 Re: Boost Gauge Tap
    Banned
    Jan 2013
    Colorado
    is that a procharger?
  5. #5 Re: Boost Gauge Tap
    Southeast, PA
    It's a Paxton Novi 1000. Works just like a Procharger.
    Should I create a thread on my cars? haha, I was hoping for a quick response on what vacuum to tap
  6. #6 Re: Boost Gauge Tap
    Feb 2009
    flintnasty MI
    Novi 1000 shouldnt even need a tune on a supercharged PCM with stock maf/injectors. If its NA you just need to put the bigger injectors in and change it to whatever.
    anything on the intake manifold will give you what your boost gauge wants.
  7. #7 Re: Boost Gauge Tap
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    I want this setup.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  8. #8 Re: Boost Gauge Tap
    Antioch, IL
    grab a vac line, T it and run to your gauge.
    2009 Challenger SRT8
    Expert at being gay.
  9. #9 Re: Boost Gauge Tap
    Southeast, PA
    OK, I'll just grab whatever line is easiest. I wasn't sure if there was a specific one that would be best or not.
    I also thought the tune would be a piece of cake, but no matter what I do, I can't go WOT without misfiring. Grabbing the L67 Tune and making the changes to my tune had the car running decent, but my fuel trims were -20s. After scaling the MAF and getting my LTFTs in check, I still can't 100% my TPS without a classic little misfire in the upper RPM band. I'm also not getting the timing advance that I want to get for power. The car should be much quicker than it is and it's so frustrating haha
    If you have HPTuners, and want to shoot me a PM, I'd gladly send a file your way.
    https://www.youtube.com/watch?v=CBanaX0qTuY
    CSC Powered 2000 Monte Carlo SS
    2013 Camaro 1LS
  10. #10 Re: Boost Gauge Tap
    Follow the brake booster to the UIM, there's a vacuum port on it.
  11. #11 Re: Boost Gauge Tap
    Feb 2009
    flintnasty MI
    Quote Originally Posted by chibiblacksheep View Post
    I see a stock maf, you should have a stock maf table.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
