Thread: Tuning Assistance - Who do you trust?
Results 1 to 20 of 32
  1. #1 Tuning Assistance - Who do you trust?
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    I know I am probably opening a huge can of ego worms here, but I would like to have someone help me with a tune for my turbo build.. Guess I am looking for someone to make me a base tune from which to work from since I am pretty new to the tuning arena and what needs to be changed for a turbo build as well.. I need reliability, not a ragged edge, squeeze every last HP out of my build tune.. Car is going to be somewhat of a DD car, also doing shows etc.. Not a track/dyno queen. SO all that being said, who would you suggest to help me with a tune?? And anyone willing to do that for me I guess would be the next q. I have a DHP tuner.. will get into build specifics with whoever I decide to go with. If you have been around my posts enough, you can probably tell most of my build anyway. Thanks in advance. Going to be a while before I am ready to turn the key so not a time pressured thing.. Just want to get my ducks in a row so to speak. Still building the transmission currently. Motor is done, lots of wiring and plumbing to do once the powertrain is in..
  2. #2 Re: Tuning Assistance - Who do you trust?
    Ohio
    Call Brian turner
  3. #3 Re: Tuning Assistance - Who do you trust?
    Feb 2009
    flintnasty MI
    luckily, tuning a turbo setup doesnt really require anything... stock timing works really good unless you are trying to run an exotic fuel. AFR is usually pretty close stock.
  4. #4 Re: Tuning Assistance - Who do you trust?
    nj
    hmm so i should put my stick timing back? im running some good timing from when i as s/c. 0 kr at 17 lbs
  5. #5 Re: Tuning Assistance - Who do you trust?
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    You aren't that far from CT. Nick is an excellent tuner. People can bash him all they want, for whatever reason they want, but he is a gdamn good tuner. Not sure when you are planning on having your car back on the road, but a few of us are gonna do a dyno day pretty soon, and im sure he would street tune, then dyno tune it for you.
    My car has never run better. with my old setup, we pushed it as far as we could safely. and when i wanted him to leave it like that, he backed it off just a little, for safety reasons. No matter how much i argue with him LOL. And now we are doing my twin charge tune and i am equally happy with the results.... cant wait for dyno day
  6. #6 Re: Tuning Assistance - Who do you trust?
    May 2012
    Albuquerque, NM
    I can't wait to get my turbo installed, maybe y'all have more on turbo tuning by then (a couple weeks). Besides changing for the injectors, anything else need done right off the bat?
  7. #7 Re: Tuning Assistance - Who do you trust?
    May 2008
    Schuyler, NE
    What are you doing with your MAF? You will probably need to change something there too, unless you are leaving it stock.
  8. #8 Re: Tuning Assistance - Who do you trust?
    May 2012
    Albuquerque, NM
    Until I get my built tranny installed in a few months I'll be running low boost. I have a modified MAF coming with the kit. I'll be using stock until I need the upgraded MAF. I have access to my N*\LQ4 set up I was going to run but I heard stock was better for turbo.
  9. #9 Re: Tuning Assistance - Who do you trust?
    Feb 2009
    flintnasty MI
    stock is better for turbo. When you max it out you will need to put a new maf table in, but its usually not that hard to figure out.
  10. #10 Re: Tuning Assistance - Who do you trust?
    May 2012
    Albuquerque, NM
    I will have a fixed AFC from ZZP on hand and waiting. The MAF coming with the kit is a "Matt M. Modified MAF", should I use that or the AFC with new table? Also, is the ported L36 (or L67) TB worth the $150?
    thanks guys
  11. #11 Re: Tuning Assistance - Who do you trust?
    Feb 2009
    flintnasty MI
    I use modded mafs and afcs, I like both.
    Porting the TB is going to cause more problems than help.
  12. #12 Re: Tuning Assistance - Who do you trust?
    Lorain, OH
    My particular build is a 98 GTP w gen3 aluminum upper/lower intake and 99+ stock tbody with a mini AFC.
  13. #13 Re: Tuning Assistance - Who do you trust?
    May 2012
    Albuquerque, NM
    He'll no am I going to pay for problems! Guess I'll stick with the stock TB and only use the AFC if the MAF is damaged.
    Thanks y'all...
  14. #14 Re: Tuning Assistance - Who do you trust?
    nj
    i got a ported tb and i have no issues that i can detect. what issues wil la ported tb give you?
  15. #15 Re: Tuning Assistance - Who do you trust?
    Feb 2009
    flintnasty MI
    hardest option to tune, least gains in max maf headroom.
  16. #16 Re: Tuning Assistance - Who do you trust?
    GT Level Member 1999black3800's Avatar
    Oct 2012
    Albany, NY
    Coppola motorsports in Malta ny thats whos doing my tune , and i no ur pretty close to him aswell
  17. #17 Re: Tuning Assistance - Who do you trust?
    Oct 2012
    West Springfield
    Quote Originally Posted by 1999black3800 View Post
    beware of coppola motorsports - LS1TECH
  18. #18 Re: Tuning Assistance - Who do you trust?
    GTX Level Member crbquist's Avatar
    Massachusetts
    Quote Originally Posted by danomite02 View Post
    ^^^THIS^^^
    Despite what many people say about him.. Nick, SlowSho, SnowFlake, and whatever other usernames he may and probably does have... Is a very good tuner. He's helped me out on a few occasions with my tune and I have no regrets. In fact, I need to hit him up again once I throw my 60# injectors in. Too bad I'm such a procrastinator. But yes, Nick definitely knows what he's doing.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  19. #19 Re: Tuning Assistance - Who do you trust?
    Mullet Member Wotgtp's Avatar
    Connecticut
    X3 on Nick. He tuned my 3.1 Gen V/NIC setup and it runs great. I doubt I'll let anyone else tune it. When I move to Vegas, I'll ship my PCM's to him. Lulz
  20. #20 Re: Tuning Assistance - Who do you trust?
    Oct 2012
    West Springfield
    X4 on slowsho/snowflake. My car has neve run better after he tuned it. Guy's a genius and has a bad ass turbo 3800.
  1. Why I don't trust 'performance shops' in general...
    By Odi in forum Off Topic Discussion
    Last Post: 05-10-2013, 02:57 PM
  2. Who do you trust?
    By SnowDrift in forum Off Topic Discussion
    Last Post: 12-24-2012, 08:30 AM
  3. ummmm...... what should i trust.
    By vtechkiller in forum Audio, Security & Visual Electronics
    Last Post: 09-06-2012, 08:13 AM
  4. do you guys trust
    By BlackGT97 in forum General Tech Discussion
    Last Post: 07-22-2011, 01:17 PM
  5. This is why i dont trust any one but me driving my car...
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 01-19-2010, 10:58 PM
