Thread: Exhaust (turbo) smoking, smells like oil...
Results 1 to 6 of 6
  1. #1 Exhaust (turbo) smoking, smells like oil...
    May 2012
    Albuquerque, NM
    Hey guys, about a month or so ago I drove about 2 weeks with a major leak in my IC piping. I was easy on the car but I think I may have screwed up/overspun my turbo. Now, my boost controller is hardly raising my boost levels and I have smoke from the exhaust. It's not huge but enough its noticeable. It only happens every now and then (I haven't seen a pattern yet), primarily at idle, and low level acceleration (IE. taking off from stop light). Is there a way I can verify its the turbo? I assume oil consumption but I haven't noticed a huge difference there.
    Also, is that screwing up my WB/O2 sensors? Would an oil restrictor inline help? Lastly, who is a reputable turbo rebuilder. Its the Stattama T67 turbo.
    TIA,
    Slim
    2003 Chevy Inpala LS 3.8 l36, Stattama Turbo kit, P&P LIM, P&P heads, lS7 lifters, Intense Xtreme 7.05 oil restricted pushrods, ZZP 1.9 modded rockers, 3" no cat down pipe, poly mount all around, fuel rewire, alt volt booster, and still working on it...
  2. #2 Re: Exhaust (turbo) smoking, smells like oil...
    Mar 2012
    NC
    You can pull the air filter off of the turbo and check for shaft play. Typically this is a worn turbo bushing kinda thing. GMR Badass (Greg) knows of a good turbo place, so it might be worth it to shoot him a PM.
  3. #3 Re: Exhaust (turbo) smoking, smells like oil...
    GT Level Member 1999black3800's Avatar
    Oct 2012
    Albany, NY
    Theres ur problem. Get a precision , or comp turbo. Stattama t67s are always going bad
  4. #4 Re: Exhaust (turbo) smoking, smells like oil...
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Stattama turbo is a Precision turbo with a Garret cold side cover on it......
    Downfall of the typical turbo out there is that they don't normally come with the upgraded step-gap oil piston ring. On a good note, the Stattama turbo comes with a 360 thrust bearing which is a nice upgrage.
    To the OP...sent you a PM. It's a $12 part to fix it and then you can have it sent off to be rebalanced for $60 if you are looking for a quick and easy reprair.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  5. #5 Re: Exhaust (turbo) smoking, smells like oil...
    Oct 2012
    Albany, NY
    Yeah... But there still cast wheel and journal bearing. I just always see ppl needing. Rebuild with them
  6. #6 Re: Exhaust (turbo) smoking, smells like oil...
    Feb 2009
    flintnasty MI
    Quote Originally Posted by 1999black3800 View Post
    precision turbos are complete junk. They couldnt even rebuild my stattama turbo.
  1. Exhaust leak between turbo and turbo DP (O2's)....
    By slimguns in forum PCM Tuning
    Last Post: 11-13-2013, 04:25 PM
  2. D exhaust ports still essential on turbo?
    By slimguns in forum Turbo
    Last Post: 09-09-2013, 10:53 AM
  3. Slight smoking coming off front exhaust manifold
    By camopaint0707 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2013, 07:17 PM
  4. 2004 GTP Comp G Exhaust Smells bad
    By daltman360 in forum 04+ Specifics
    Last Post: 05-14-2013, 04:41 PM
  5. NA / Turbo Exhaust?
    By Confusingboat in forum General Tech Discussion
    Last Post: 02-01-2011, 07:53 AM
