Thread: different cam for the twincharged GTX
Results 1 to 20 of 21
  1. #1 different cam for the twincharged GTX
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    st2 st4 or st5 READY GO!
  2. #2 Re: different cam for the twincharged GTX
    Aug 2011
    'Merica
    Go big or go home......
  3. #3 Re: different cam for the twincharged GTX
    Go as big as you can!
    04 Comp G.
  4. #4 Re: different cam for the twincharged GTX
    Dec 2010
    ATL,Georgia
    St6!!!!
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  5. #5 Re: different cam for the twincharged GTX
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    What cam were you running?
  6. #6 Re: different cam for the twincharged GTX
    Jul 2011
    CT
    Quote Originally Posted by 231FUN View Post
    Was running the XP
  7. #7 Re: different cam for the twincharged GTX
    Florida
    ST5 and just be awesome.
  8. #8 Re: different cam for the twincharged GTX
    Custom grind.
  9. #9 Re: different cam for the twincharged GTX
    Banned
    CT
    4th option... my turbo cam.
  10. #10 Re: different cam for the twincharged GTX
    Jul 2011
    CT
    st 2 cam cost for me used 200 st 5 cam new 285 hmmmm
  11. #11 Re: different cam for the twincharged GTX
    Quote Originally Posted by danomite02 View Post
    $85 difference
    New > used
    St5> St2
    04 Comp G.
  12. #12 Re: different cam for the twincharged GTX
    st5 takes headwork right? and bigger springs and chain, Me personally Id do the St2 not as big which I would think would be less of a headache to get dialed in than the st5. IIRC the st2 isn't that much different than the xp cam as far as specs, could be wrong havnt looked at them specs side by side in a while.
  13. #13 Re: different cam for the twincharged GTX
    Banned
    CT
    I'm dialing it in and I want him to go as big as possible.
  14. #14 Re: different cam for the twincharged GTX
    Dec 2011
    Ontario,Canada
    Don't bother with an st2 if you already have an xp unless you hurt the xp with your timing chain incident that is and want to stay with a smaller cam, the specs are pretty close to identical between the xp and st2 if you look at them. I'd go with the st5 if it was me buying and considering your options.
  15. #15 Re: different cam for the twincharged GTX
    Jul 2011
    CT
    nah the xp is fine(as in not damaged when the chain snapped) Just weighing my options.
  16. #16 Re: different cam for the twincharged GTX
    Banned
    CT
    the xp is fine
  17. #17 Re: different cam for the twincharged GTX
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    ST5. Go big or go home. You've already twincharged the car, why stop there?
  18. #18 Re: different cam for the twincharged GTX
    Feb 2009
    flintnasty MI
    doesnt really make much of a difference. SPrings are a bigger deal.
  19. #19 Re: different cam for the twincharged GTX
    hangover park IL
    im sorta with dark on this one....id bias towards a smaller duration cam and bias the build towards tq than top end power...cams dont make much difference for us up top with our horrible rod/stroke ratio and its effect of killing cylinder filling at high rpm. doesnt mater how you fart with valve events when the piston acceleration rate is exceeding the volume filling of the oem intake tract/ports/throat...id bet your pressure ratio really starts to rise.....almost retarded to try to shoot over 6500rpm. might as well put a honda 4 banger in a mining truck while your at running things outside their design envelope...
    we made 540whp unlocked with an st1r (st1 with more lift) at 18psi and stock qwikported heads with 130's, 608fwhp and 575ftlbs with the tcc locked
    shoot man **** the cam i just want a trans to hold together...thankfully i now have a l60e bellhousing to make an engine dyno adaptor for Opel up the street...delete the weak link lol
    ~James~ Psychotic Gearhead
  20. #20 Re: different cam for the twincharged GTX
    Dan.. there is a lot of good knowledge in the last two posts, as well as a lot of actual trial and error. Going as big as possible is an ego trip, not a good build plan. Many of the guys that keep things reasonable make amazing amount of power for the parts involved vs the biggest meanest parts available. You aren't the guy that is worried about putting a part in to say you have it, you're the guy that puts in low cost, easy availability and then looks at the guys with the bigger parts etc in his rearview.
  1. Twincharged GTP dyno video
    By ls1camino in forum Turbo
    Last Post: 02-07-2013, 12:10 PM
  2. Vac source for BOV on Twincharged setup
    Last Post: 08-01-2012, 10:55 AM
  3. Cam for Twincharged GTP
    Last Post: 02-17-2012, 03:09 PM
  4. STS twincharged
    By funky4stringed in forum Turbo
    Last Post: 07-08-2010, 12:54 AM
  5. Twincharged L67 in a Cutlass
    By AlphaBetaBase in forum Off Topic Discussion
    Last Post: 01-03-2008, 01:42 PM
