I ask because a reliable source said I could and the ZZP photo of the Z7 kit doesn't appear to have one. Also my install didn't mention it. What do y'all think?
I'd run one.
Its not like its hard to relocate the sensor. Our PCM can use that temp to pulling timing if it thinks the air coming in is too hot, which can help save itself.
I'd run one, same reason FFDP said. Just put it in one of the silicone adapters (like right at the TB)
I'll be running between 6-15 PSI, won't that leak or worse, pop out (giant leak)?!
Just put a small bead of silicone around it if you're worried about it popping out, though it shouldn't.
Cool, thanks guys!
the TR's is hanging in front of the radiator behind the grill via extended wires
SI 3800 IAT's are thread in 3/8ths npt so you can weld a bung onto a pipe for a more secure setup.
i wanna put one in each end tank of the IC with a signal switch for some info via the datalogs
my 97 gtp its hanging next to the HAI cone lol
In my 97 it was zip tied to the throttle body for a while then I redid my intake and put it in the rubber tube I noticed no difference between the 2. Unless you absolutely want to know what your intake air temp is I would just say leave it off.
