Thread: turbo help
Results 1 to 20 of 21
  1. #1 turbo help
    nj
    quick question, i currently have a t61, would the turbonetics 60-1 be considered an upgrade from my t61?
  2. #2 Re: turbo help
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    do you have any specs for your t61? Ball or journal bearing (same question for both turbos)
  3. #3 Re: turbo help
    nj
    only thing about my turbo i know is that it came with the ct kit, its a Precision PT61 Turbo. 60-1 is ball
  4. #4 Re: turbo help
    May 2008
    Schuyler, NE
    I believe you would be going backwards, but it's tough to say without knowing the 60-1 specs.
  5. #5 Re: turbo help
    nj
    i believe its a 60mm compressor wheel, ball bearing, liquid cooled
  6. #6 Re: turbo help
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Precision PT61 that commonly came with the Cartuning Kit
    Turbo is a Precision PT61
    T4 .69 A/R On-Center Housing
    3" inlet / 2" outlet (E compressor cover)
    4-bolt On-Center exhaust flange
    Precision 6152E rated at 630hp
    61.8mm inducer compressor wheel
    62mm Stage 5 turbine wheel
    360 journal bearing
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  7. #7 Re: turbo help
    nj
    GMR any info of the turbonetics 60-1?
  8. #8 Re: turbo help
    Apr 2011
    Columbus, OH
    Quote Originally Posted by silver3 View Post
    Too many variables.....Once you have a part number or something else to go by I'll be able to provide a little more info.
    They are roughly about the same in theory......I'd suggest the 62-1 if you're looking for a slight upgrade
  9. #9 Re: turbo help
    nj
    Hmm ok. Would you say the t67 would be too big?
  10. #10 Re: turbo help
    Apr 2011
    Columbus, OH
    Some will argue that yes it's too big but on the other side of the argument is that everyone that has gone to the bigger turbo has never looked back. Everyone that has stepped up to the T67 (or equivalent) has loved it.
  11. #11 Re: turbo help
    nj
    Hmm your opinion, I have 2.5 pipes. Would that be too restrictive?
  12. #12 Re: turbo help
    Apr 2011
    Columbus, OH
    There are people that have taken the 2.5" downpipe w/cutout to 550whp. With 3" downpipe it's a whole lot easier to hit the number. What are your overall goals?
    I have a CT kit with a PT61 and as a DD it was a fun ride. Now that I have a 1" GMR I want to jump to the bigger turbo kit.
  13. #13 Re: turbo help
    nj
    No set goals bc I have no trans work. It's also my dd. just want something bigger just incase if I want to mod again ill be good.
  14. #14 Re: turbo help
    Apr 2011
    Columbus, OH
    The Precision PT61 will be more than enough keep you happy for quite some time.
  15. #15 Re: turbo help
    Ohio
    These engines can put up a very large turbo. Even a t67 isn't "big" for these.
  16. #16 Re: turbo help
    nj
    Ok sounds good. I may have it rebuilt. There's a nick on the blade.
  17. #17 Re: turbo help
    nj
    Quote Originally Posted by MoarkatsINmuhtrailer View Post
    Yea I heard the 3800 are good engine and can withstand a lot. One day when it's not my dd ill do more
  18. #18 Re: turbo help
    Texas
    T67 is money sauce on a 3800, but it's not worth it unless you upgrade to 3" exhaust.
    85 Corvette
    01 TA
    03 Z06
  19. #19 Re: turbo help
    nj
    I was considering doing a 3" from the dp to tips or just a 3" dp with cutout
  20. #20 Re: turbo help
    Apr 2011
    Columbus, OH
    The 3" is nice but if you're on a budget stick with the 2.5" downpipe. Cartuning kit has been running them for years and people have had no problems putting down 500whp. I always mod on a very tight budget. Are you going to be tracking the car at all? Or you said that it was going to be your DD.
    350whp makes it difficult to get traction
    450whp almost impossible to get traction
    550whp is just silly on the street
  1. Replies: 23
    Last Post: 03-26-2014, 02:22 PM
