MMS 3800 W-body Turbo Kit - Milzy Motorsports
but they want alot of money for it lol
might fit SI 3800's.
But ebay intercooler. Not good.
You can do a lot better than an ebay intercooler.
Granted you can make enough power to render the ebay ones useless.
"Please note until we update our pictures, the picture above is actually from our N-body kit, but the design is very similar."s
Looks like it's not the pic of the actual kit. Looks like quality work.....but man that's putting it as more expensive than that Stattama Kit which is the best one on the market.
Never had an issue with my coolant temps just saying
And I'm pretty sure sal is running the same ic on his car.
Coolant temps?
You mean post intercooler air temps?
Are they within 10* of ambient? If not, you could do better. Are the consistent throughout the quarter mile run? Or do they rise significantly?
Weaker designs tend to float higher than ambient at cruise, and increase greatly the longer the run. The better designs will hold ambient temps out of boost, and hardly increase during a run. Unless of course you're past the limits of the thing, or using a compressor outside of its efficiency range. Or just using a mediocre compressor to start with.
All the things no one cares about in a W body. If it runs without KR, its good right?![]()
I'm always within 10* of ambient
And no you said these block airflow to the radiator, I've never had an issue with my radiator. Steady at 175 like normal.
air to air intercoolers are all about flow vs cooling... Just because one intercooler flows more and cools less does not make it "bad".
Anyway, this turbo kit looks like an utter pile of junk. Stupid header style manifolds are stupid, no flex joints anywhere, and the tiny tiny crappy fitting bent up downpipe looks like a complete mess. Stock manifolds and a hacked together downpipe with a CT style wg perch would work better than that mess, and you could do it for $100.
