Thread: 3" downpipe?
Results 1 to 6 of 6
  1. #1 3" downpipe?
    GT Level Member DaytonaGTP500's Avatar
    May 2012
    Iowa
    Hey guys jus tryin to get some opinions here. When is it needed to run a 3" downpipe? Im currently in the middle of a build and have been tryin to figure out if 3" is needed or not.... I'ma be running e85, s259 Turbo, ported heads, ST4 cam n blahh blahh. Hopefully a little above six after I'm done and on the dyno. I have 2.5"already moded with the 3" v-band(to hook to the Turbo).
    Will I be good you think on jus the 2.5 or? I already have an exhaust dump welded on the tog dp into a non catted 3"zzp exhaust too. Thanks guys!!
  2. #2 Re: 3" downpipe?
    new britain, ct
    youll want a 3".
    07 Black GXP.
  3. #3 Re: 3" downpipe?
    Ohio
    Good luck making 600 on a 2.5.
  4. #4 Re: 3" downpipe?
    new britain, ct
    might want a cutout too
    07 Black GXP.
  5. #5 Re: 3" downpipe?
    May 2012
    Iowa
    Yea I got a cutout welded into the tog already, n that's kinda wut I figured but them ****ers are pricey and a bit more work yet so I figured I'd double check with it. Thanks for the help guys
  6. #6 Re: 3" downpipe?
    GT Level Member ls1camino's Avatar
    Laurel, MD
    Do the 3" and don't look back.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  1. Exhaust questions (3" downpipe = 3" Cat?)
    By aeidian in forum General Tech Discussion
    Last Post: 03-14-2012, 01:48 AM
