Thread: Valve cover breather
Results 1 to 7 of 7
  1. #1 Valve cover breather
    Apr 2011
    Tally, FL
    does this wreck havoc with the wideband? mine seems to bouncing all over the place from 14-17
  2. #2 Re: crankcase breather
    Minnesota
    It allows unmetered air into the motor. if your not intercooled take it off. And even if you are I would try to set up a catch can set up to get rid of the vacum leak
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  3. #3 Re: crankcase breather
    Breathers are only needed if the cars PCV system is no longer there.
    And the WB should only be bouncing from 14-16 while at idle and crusing as its trying to stay as close as it can to stoich.
  4. #4 Re: crankcase breather
    Apr 2011
    Tally, FL
    Well i tapped the pcv hole on the throttle body and plugged it like the instructions said
  5. #5 Re: Valve cover breather
    SE Level Member BlackGS's Avatar
    Central Jersey
    Turbo cars require the breather or an air pump. You cannot have a PCV system with the inlet after the turbo because the turbo will pressurize your crankcase and destroy seals, so the breather becomes the inlet. If you still have your PCV valve functioning, the air coming in from the breather will circulate back into the cylinders after the MAF, so will add air to the mix that the tune does not know about. It is very little air, and does not create any problems. The fluctuation of AFR from 14 to 17 is because of closed-loop, not because of the extra air. If you want your wideband to read steady at idle and cruise, you would have to switch to an open loop tune, but it is not necessary. Closed loop works fine. Just make sure to tune correctly for part-throttle as well as full throttle.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  6. #6 Re: Valve cover breather
    Apr 2011
    Tally, FL
    Yeah im having trouble with alot of kr at part throttle but barely any once i start to get on it because the car is too rich.
  7. #7 Re: crankcase breather
    May 2012
    Albuquerque, NM
    Quote Originally Posted by DoubleBlown View Post
    Ehere are these instructions you speak of? I'm doing my build this weekend and was wondering how to disable the pcv?
  1. crankcase not vented on these motors?
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2011, 07:44 AM
  2. Valve cover Breather
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2011, 06:27 PM
  3. Crankcase Vacuum help!?
    By Damon318 in forum General Tech Discussion
    Last Post: 11-17-2010, 02:51 AM
  4. Crankcase vacuum?
    By RedGT99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-26-2010, 03:52 PM
  5. crankcase ventilation valve?
    By jmanners in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-10-2009, 08:54 PM
