Thread: turbo guys chime in please
Results 1 to 10 of 10
  1. #1 turbo guys chime in please
    GTP Level Member joshv's Avatar
    canada
    had the day off today and decided to clean up my engine bay and areas, took apart the intake tube as im not intercooled yet. and the intake is lined with oil. not enough to tip it upside down and have oil run out but it is oily. and noticed the bov area has a little bit of oil on it. i checked the shaft play on the
    turbo and it moves up and down very slightly but does not move in and out at all... im thinking the turbo is getting to much oil or not draining properly.
    any help is appreciated!
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  2. #2 Re: turbo guys chime in please
    Texas
    Quote Originally Posted by joshv View Post
    Or one of your seals is leaking.
    85 Corvette
    01 TA
    03 Z06
  3. #3 Re: turbo guys chime in please
    Jan 2013
    cincinnati
    Ya I'd say high pressure leaking seal, what angle is your drain?
  4. #4 Re: turbo guys chime in please
    May 2008
    Schuyler, NE
    Double check your drain.
    What turbo are you running? You may need an oil restrictor.
  5. #5 Re: turbo guys chime in please
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    I had a similiar case with my turbo too. Running a PT61 with the Cartuning kit and had it rebuilt by g-pop shop before I put the used turbo kit on. I'm running a restrictor and had the same questions. I called up G-Pop shop and they said that some is to be expected. I'm going to keep checking every couple of month for any additional shaft play since it has a 1-yr warranty. If it's a light hazing I was told it was to be expected. I'm running the supplied drain kit from Cartuning which has a 45 degree bend to start with a straight shot to the oil pan after that.
    Edit...was also told that if you are running to much oil pressure that the first seal it's going to blow by is the exhaust side and you'll see that your car is burning a little bit of oil.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  6. #6 Re: turbo guys chime in please
    canada
    im running the PT66 turbo and aswll i am using cartunings restrictor. it basicly looks like a light hazing but iv always got that " what iff " in the back of my mind lol.
  7. #7 Re: turbo guys chime in please
    nj
    im also running a ct kit and i did notice the light hazing. from what i read and from what i was told, is that its normal to have a little as stated above. i want to try an oil restrictor and see what happens.
  8. #8 Re: turbo guys chime in please
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    Some oil in the intake system is normal, depending on what you have for a pcv setup.. Those with a catch can etc I think have less oil in the intake issues than those just running a breather on the v/c.
  9. #9 Re: turbo guys chime in please
    canada
    I am not running an oil catch can or a breather haha but i think im gunna order and oul catch can
  10. #10 Re: turbo guys chime in please
    nj
    im running both can i have some. lol
  1. Chime, chime, chime, chime
    By mainjet in forum General Tech Discussion
    Last Post: 11-01-2011, 03:30 PM
  2. Talk to me guys. Turbo for my comp g
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2011, 12:42 AM
  3. Chime
    By zildjian102 in forum Audio, Security & Visual Electronics
    Last Post: 01-17-2011, 06:42 PM
  4. Replies: 0
    Last Post: 11-07-2009, 06:30 PM
