Thread: Adding More Boost Z7 Kit
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #1
    Aug 2011
    Kenosha
    Quote Originally Posted by ARFF22 View Post
    What about this hook up?
    That is exactly how I have always hooked mine up.
  2. #2 Re: Adding More Boost Z7 Kit
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    I have mine setup @15psi the same way shown in the diagram Black GS posted.
    1.Line from vac source in to MBC
    2.Line out from MBC into top of wastegate
    3.Line from bttom of wastegate back to vac source
    SIMPLE! It's been setup like this for 6+ years...very reliable.
  3. #3 Re: Adding More Boost Z7 Kit
    She's running 16# now without any other changes than 130# springs
  4. #4 Re: Adding More Boost Z7 Kit
    GXP Level Member
    Mar 2015
    Tomball
    So what happened between 2012 and now?
  5. #5 Re: Adding More Boost Z7 Kit
    Nothing other than hooking the bc up and swapping springs
  6. #6 Re: Adding More Boost Z7 Kit
    GTP Level Member
    Jan 2015
    Lincoln, NE
    holy **** balls...first it depends on what type of MBC you actually have. there is a difference between bleed type and ball and spring. take a look at this and then report what make and model MBC you actually have so we can get you a correct diagram for you vacuum line routing.
    http://www.enginebasics.com/Advanced...ntrollers.html
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  7. #7 Re: Adding More Boost Z7 Kit
    I routed it right
  1. Adding HUD and a DIC to your 97-03 GP
    By $03gp/gt$ in forum How To Write-Ups/Tech Tips
    Last Post: 10-12-2015, 07:25 PM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  4. Adding HUD ??
    By aries83 in forum Visual/Body Modifications
    Last Post: 03-16-2009, 07:45 PM
