Thread: Cooling down my IATs in my Twincharged Setup
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21
    Why not contact spearco and hav them make one that suits your space?
    Itd cost more but be of higher quality.
  2. #22 Re: Cooling down my IATs in my Twincharged Setup
  3. #23 Re: Cooling down my IATs in my Twincharged Setup
    Ohio
    hes got the cowl...hes got the room..i say v mount
  4. #24 Re: Cooling down my IATs in my Twincharged Setup
    no, you literally need a hole in the hood. you have to push air through it and the air has to go somewhere. you need that low pressure area on top of the intercooler, with a hole in the hood, to pull air through from the air dam under the car. look up v-mounts. you need a hole in the hood.
  5. #25 Re: Cooling down my IATs in my Twincharged Setup
    Ohio
    i know he needs a damn hole nick, i know how they work.
    Lol at gp people caring about airflow.
  7. #27 Re: Cooling down my IATs in my Twincharged Setup
    Ohio
    lol honestly, an a2a could just be fitted in the bumper, wherever he can, and that would be plenty.
  8. #28 Re: Cooling down my IATs in my Twincharged Setup
    Jan 1970
    Maquoketa, Iowa
    I think you may be the first twincharged setup i've heard of without an intercooler post turbo and pre supercharger. I've seen setups without a cooler after the supercharger. That little cooler under the supercharger is not going to keep up with the temps. An A2A post turbo and a W2A for post SC is an ideal setup. If you really want to keep the bumper support i'm sure you could get a very large fmhe and run 2 W2A cores post turbo and another post SC.
  9. #29 Re: Cooling down my IATs in my Twincharged Setup
    GT Level Member ls1camino's Avatar
    Laurel, MD
    Quote Originally Posted by FoSHO99 View Post
    I think this is what I am going to do.
    I'm probably going to run a 24x12x3 A2A Intercooler post Turbo with a 24x12x1 A2W Intercooler post Super. I'm just curious which one should be put in front?
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  10. #30 Re: Cooling down my IATs in my Twincharged Setup
    Jan 1970
    Maquoketa, Iowa
    The A2A will probably only work out front, the piping and just the way it is mounted needs a little bit more space. You want the A2A out front anyway to do it's job.
  11. #31 Re: Cooling down my IATs in my Twincharged Setup
    SE Level Member BlackGS's Avatar
    Central Jersey
    My twin-charged setup is running two water-to-air cores, one after the turbo, and one under the supercharger, both using the same FMHE (Frozen Boost type 101). The turbo core is a 12x12x4.5 unit mounted in the driver-side bumper. I had to cut a little bit of sheet metal to get it in there. I routed the water line like this: FMHE->pump->sc core->turbo core->reservoir->FMHE.
    Before I added the turbo intercooler, I was running just the sc core, and I was only able to get about 15psi/15* timing (mid 12's time). After the turbo core, I raised the boost to 18psi with 20* timing on 93 gas. You should definitely get either the air or water intercooler for the turbo to reduce those temps.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  12. #32 Re: Cooling down my IATs in my Twincharged Setup
    Banned
    Jun 2012
    Sacramento CA
    Quote Originally Posted by ls1camino View Post
    You can stack them if you got creative. Cutting out the bumper support would be pretty much mandatory though... Run the A2W above the A2A.
    You could also run a small A2A side mounted in the driver side fender well. It wouldn't be ideal but if you made an air duct it would be 100 times better than no intercooler, and you could keep your bumper support.
    Good luck with whatever you decide, you will pick up good power for sure.
  13. #33 Re: Cooling down my IATs in my Twincharged Setup
    Texas
    I vote a small shot(35) of nitrous pre-turbo.
    85 Corvette
    01 TA
    03 Z06
  14. #34 Re: Cooling down my IATs in my Twincharged Setup
    Yoga city
    how about go rice and run no hood?
  15. #35 Re: Cooling down my IATs in my Twincharged Setup
    Quote Originally Posted by Jteske88 View Post
    that wouldn't help intake temperatures. go along now, little one.
    Quincy, Mass
    I was able to keep part of my bumper support but if I get in an accident the ic will be damaged but its only $150. If you remove your hood latch support bar then you will definitely have room to run both.
    No more GP 04 Impala SS Indy:
  1. Vac source for BOV on Twincharged setup
    By ls1camino in forum Turbo
    Last Post: 08-01-2012, 10:55 AM
  2. Cam for Twincharged GTP
    Last Post: 02-17-2012, 03:09 PM
  3. STS twincharged
    By funky4stringed in forum Turbo
    Last Post: 07-08-2010, 12:54 AM
  4. Twincharged L67 in a Cutlass
    By AlphaBetaBase in forum Off Topic Discussion
    Last Post: 01-03-2008, 01:42 PM
