Thread: cam valvesprings and retainer questions!
Results 1 to 20 of 21
  1. #1 cam valvesprings and retainer questions!
    GT Level Member grandprix5's Avatar
    brownsville
    hello im going to install the stattama st2 cam in my l29 my car is turbo what supporting mods do i need for that type of cam ??? i heard that i need to use the ls1 retainers ...would the springs also work good for cam?? or maybe the ls2 springs ?? im asking thos questions because i have a set of ls1 and ls2 springs and retainers !!
  2. #2 Re: cam valvesprings and retainer questions!
    Mullet Member Wotgtp's Avatar
    Connecticut
    Retainers you can use, springs you might be able to, but I don't know the spring rates. I have LS6 springs on my car with my rockers.
  3. #3 Re: cam valvesprings and retainer questions!
    Might want to go at least 105's or LS6's.
    You'll need LSx retainers.
    3800 retainers would have your springs compressed too much, probably result in binding.
  4. #4 Re: cam valvesprings and retainer questions!
    Apr 2009
    Fort Worth TX
    Would the stock timing set be OK to run with the LSx springs and higher lift cam?
  5. #5 Re: cam valvesprings and retainer questions!
    You are turbo charged yet don't know what supporting mods you need to run a cam?
    To me that is very odd.
  6. #6 Re: cam valvesprings and retainer questions!
    brownsville
    Yes my car its turbo charged 100% build by me every single part was custom made by me and runs pretty fast for me i just need help with a cam that i bought so any one knows whats the specs for the ls6 valve springs ?? Or is anyone selling 105lb valve springs??or where i can find them cheap?
  7. #7 Re: cam valvesprings and retainer questions!
    brownsville
    Oh sorry not ls6 i need the spec for ls2 valve springs thanks.
  8. #8 Re: cam valvesprings and retainer questions!
    Feb 2009
    flintnasty MI
    ST2 REQUIRES 130s.
    Ohio
    Scott how high of shift points do you run on the st2?
    Been wanting to ask you.
  10. #10 Re: cam valvesprings and retainer questions!
    Feb 2009
    flintnasty MI
    "when it stops making power"
    You wont find a limit so you can basically shift it whenever... Due to my gearing/tires/horsepower, i shift it high, but for most guys it wont matter much.
  11. #11 Re: cam valvesprings and retainer questions!
    Ohio
    well with lower shift points then you go to id assume you wouldnt float the 105s.
  12. #12 Re: cam valvesprings and retainer questions!
    brownsville
    I was talking to stattatam customer support a?nd they said that ls6 springs were ok and that the comp105 were perfect and the 130 were not requird i dont want to use 130s becuase they told me i would need to change ghe timeing chain to dobble roller and i dont want to buy a dobble roller timing chain any help on what should i do i have the stattama stage2 turbo cam i also have the ls1 retainers i just need help on the springs my shift points are at 62000rpm but it will be retuned after the cam install what shift point would you guys recommend
  13. #13 Re: cam valvesprings and retainer questions!
    F7 helps because, that was one awesome run on sentence.
    105's with a new timing chain/dampner will be fine.
    Keep the shift points at 6200.
    Enjoy.
  14. #14 Re: cam valvesprings and retainer questions!
    Saratoga NY
    Quote Originally Posted by 99pgpgt View Post
    Whats the point of a turbo and cam if you are not going to setup the valve train properly to shift it where you should?
    Cylinder pressure causes valve float, depending on the setup it could float at 4k.
    Can you get away with 105s on a mild blower cam setup? YES. Can you do it with a turbo? No.
    My car floats my 105s and they aren't even the crappy comps.
    IF you have a turbo and an aftermarket camshaft you are only going backwards by using a poor spring rate.
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
  15. #15 Re: cam valvesprings and retainer questions!
    Connecticut
    Quote Originally Posted by grandprix5 View Post
    And I laughed.
    But seriously what blucheesetp91 said.
  16. #16 Re: cam valvesprings and retainer questions!
    brownsville
    I guess no dout going with dobble roller 130s and a good tune .... Sad part i will have to wait longer to get the car started ;(
  17. #17 Re: cam valvesprings and retainer questions!
    Apr 2009
    Fort Worth TX
    Dobble????
    How about double.
  18. #18 Re: cam valvesprings and retainer questions!
    EFFFFSEVENNUB.
    I want pics of said custom turbo setup TBH.
  19. #19 Re: cam valvesprings and retainer questions!
    Ohio
    dude i dont get this guy at all (the op)...
    says hes doing an st2...yet then he is asking people to trade for 1.9 rockers or a meth kit..
  20. #20 Re: cam valvesprings and retainer questions!
    Apr 2009
    Fort Worth TX
    I noticed that as well. Why trade your cam when your asking about mods for the Stattama ST2. Maybe he changed his mind?
    OP?
  1. Important: ZZP Retainer Issues
    By BillBoost37 in forum General Tech Discussion
    Last Post: 04-04-2012, 10:29 AM
  2. PCV Valve and Retainer for Gen V Supercharger
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2010, 07:53 AM
