Thread: Turbo build. Run and tell that.
Results 41 to 60 of 61
  1. #41 Re: Turbo build. Run and tell that.
    Mullet Member Wotgtp's Avatar
    Connecticut
    DH are you talking about stockers with modded maf's as well, or just bone stock how it came from the factory mafs? Then why does everyone seemingly use modded 99+ mafs or ls/lt1's?
    The maf will read that high but our pcm won't know what to do.
  3. #43 Re: Turbo build. Run and tell that.
    Connecticut
    Saying that....is there a way to tune the pcm so it'll correctly read it on the higher scale, instead of swapping mafs or installing zzp pigtails?
    Quote Originally Posted by Wotgtp View Post
    Don't think so. Hence amazing things zzp has for us.
  5. #45 Re: Turbo build. Run and tell that.
    Ed...what's the "run and tell that" in yoru title about?
    Ohio
    Run and tell that homeboy...
  7. #47 Re: Turbo build. Run and tell that.
    Texas
    I stand corrected he is speaking in regards to the factory MAF, but you will have to tweak the PCM to understand what it's supposed to do. Otherwise it will be like am I supposed to do over 11,500 Hz
    85 Corvette
    01 TA
    03 Z06
  8. #48 Re: Turbo build. Run and tell that.
    Connecticut
    I see, thanks for the posts everyone. I think I'll try to find a used afc first, this way I can keep the intake piping simple and since I'm keeping the stock tb I may as well use the stock maf.
  9. #49 Re: Turbo build. Run and tell that.
    Connecticut
    Are all turbo blankets the same to a certain extent? I'm thinking of getting a cxracing one since I have a coupon for 15% off my whole order from them.
    Ohio
    Yeah it's all the same material.
  11. #51 Re: Turbo build. Run and tell that.
    Connecticut
    Cool, thanks.
  12. #52 Re: Turbo build. Run and tell that.
    Connecticut
    Update, I could use some help for deciding what to do on the WG setup.
    I want to run a dump tube on the WG to the bottom of the car, not into the DP. Does anyone know of, or have pics of this on a Z7 set up? Also I'm having doubts about running the 44mm WG, I'd love to have it, as there's really no such thing as too much WG IMHO. However it seems like a decent undertaking to cut and reweld as needed on the crossover to use the 44mm instead of a 38mm. I scored a good deal on it, so I don't mind trading it plus cash for a 38mm, or just cash. Thoughts?
    Also what coupler should I get for the stock TB to 2.5 inch intake piping? I measured it once but I forget lol.
  13. #53 Re: Turbo build. Run and tell that.
    Feb 2009
    flintnasty MI
    uh yeah there is?? The bigger wastegate you have the LESS accurate boost control you have.. The big gates are only around to make low boost on big turbos.
    If you want to fun dump the wastegate, you can run it into the fender, out the hood, front bumper.. etc....
  14. #54 Re: Turbo build. Run and tell that.
    Connecticut
    I was under the impression that with bigger WG's the higher amount of exhuast flow, I haven't heard of what you're talking about. Not saying your wrong, just saying. Also I appriciate the effort, but having that pic doesn't really help me. I'm looking for a GP set up pic, I already understand the concept. I'm just looking for what people did, if they did it, on their GP. Thanks
  15. #55 Re: Turbo build. Run and tell that.
    SE Level Member newfie's Avatar
    Toronto, Canada
    Did you figure out what to do with the rear exhaust manifold?
    634whp 10.9@127mph '99 GTPT
    CT "lumpidy" Engine, Big Turbo, CT Trans, 3" Cut-out, Magnaflow's, AGX's, Eibach's, GMMP/BMR's, FBod Brakes, Xenon's, AE 077's, Kumho 711's
    http://www.cartuning.ca
  16. #56 Re: Turbo build. Run and tell that.
    Connecticut
    I'm going to be running a rear plog..
  17. #57 Re: Turbo build. Run and tell that.
    Toronto, Canada
    I ran a stock ported rear with a #4 and #6 turned when I made 624 WHP with no issues. If you have the means to cut/weld and turn the rear, it may be a cheaper route that would work just fine
    Ohio
    Newfie can you post a pic of the turned manifold.. I've never seen one and thought about doing it for mine.
    Ed sorry about the thread jack but I figured you wouldn't mind
  19. #59 Re: Turbo build. Run and tell that.
    Connecticut
    Thanks, but I don't weld and to have a shop do it, I might as well get a new piece.
    Don't worry about it 99p, I'd like this thread to be full of any turbo information. I want this thread to be a good reference point for as many people as possible.
  20. #60 Re: Turbo build. Run and tell that.
    Doesn't a turned primary make changing that plug rather difficult?
  1. Need help with my turbo build
    By Classy Pontiac in forum Turbo
    Last Post: 11-09-2011, 08:38 PM
  2. turbo build
    By Twist in forum Turbo
    Last Post: 10-13-2011, 12:30 PM
  3. planning a turbo build
    By nascartech in forum Turbo
    Last Post: 02-10-2011, 06:59 PM
  4. Few turbo questions for the build!
    By 98GT3800 in forum Turbo
    Last Post: 08-13-2010, 08:42 PM
  5. Turbo build soon to come.
    By bbptech in forum Turbo
    Last Post: 03-05-2010, 09:37 AM
