Thread: Custom Turbo Setup
Results 1 to 14 of 14
ImColeTrickle Custom Turbo Setup 01-23-2012, 08:47 PM
blueguy Re: Custom Turbo Setup 01-23-2012, 08:47 PM
Classy Pontiac Re: Custom Turbo Setup 01-23-2012, 08:51 PM
ImColeTrickle Re: Custom Turbo Setup 01-23-2012, 08:54 PM
MoarkatsINmuhtrailer Re: Custom Turbo Setup 01-23-2012, 08:55 PM
ImColeTrickle Re: Custom Turbo Setup 01-23-2012, 09:05 PM
txslow6 Re: Custom Turbo Setup 01-23-2012, 09:39 PM
FoSHO99 Re: Custom Turbo Setup 01-23-2012, 11:15 PM
Classy Pontiac Re: Custom Turbo Setup 01-24-2012, 07:52 AM
FoSHO99 Re: Custom Turbo Setup 01-25-2012, 09:33 AM
Classy Pontiac Re: Custom Turbo Setup 01-25-2012, 01:01 PM
Tuner-Extraordinaire Re: Custom Turbo Setup 01-23-2012, 11:20 PM
darkhorizon Re: Custom Turbo Setup 01-26-2012, 12:24 PM
ImColeTrickle Re: Custom Turbo Setup 02-07-2012, 01:23 AM
  1. #1 Custom Turbo Setup
    SE Level Member ImColeTrickle's Avatar
    Apr 2011
    Athens, Alabama
    Is it smarter to construct my own turbo setup or spend 3 grand on a kit from ZZP?
  2. #2 Re: Custom Turbo Setup
    Hmmmm...
  3. #3 Re: Custom Turbo Setup
    GTP Level Member
    Sep 2011
    Motown
    well I am personally constructing my own.
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  4. #4 Re: Custom Turbo Setup
    Apr 2011
    Athens, Alabama
    well what all would you need? Id like it to be sort of like ZZPs Z3 kit
  5. #5 Re: Custom Turbo Setup
    Ohio
    its usually cheaper to construct your own setup. piping you can find on the boards. same with the turbo. oil feed line, wastegate, intercooler and piping can be had for about 200? you could probably make a decent setup for around 1500 or so
  6. #6 Re: Custom Turbo Setup
    Apr 2011
    Athens, Alabama
    Alright thanks. Any suggestions on what turbo to run?
  7. #7 Re: Custom Turbo Setup
    Texas
    Depends on how much power you want to make.
    85 Corvette
    01 TA
    03 Z06
  8. #8 Re: Custom Turbo Setup
    Jan 1970
    Maquoketa, Iowa
    Part of the cost of the Z3 kit is not having to do the research and having a complete kit with warranty and a reputable point of contact for questions. If you are unsure or don't know what a wg/bov actually do, then constructing your own kit may not pay off in the end.
  9. #9 Re: Custom Turbo Setup
    GTP Level Member
    Sep 2011
    Motown
    Quote Originally Posted by FoSHO99 View Post
    Ok i noticed your signature said weak fuel pump. If i kept my stock fuel pump from a 06 could i even push 9 psi. If i could how long would it last?
  10. #10 Re: Custom Turbo Setup
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by Classy Pontiac View Post
    It'd be fine, I'm running E85 which requires more fuel and I had some gummed up crap in the tank that killed the pump as well.
  11. #11 Re: Custom Turbo Setup
    GTP Level Member
    Sep 2011
    Motown
    Thx for the info.
  12. #12 Re: Custom Turbo Setup
    Out West
    Quote Originally Posted by ImColeTrickle View Post
    Talk to Scott. $800 and 450whp
    Whine with your Cheese?
  13. #13 Re: Custom Turbo Setup
    Feb 2009
    flintnasty MI
    Quote Originally Posted by Nixon View Post
    ez.
  14. #14 Re: Custom Turbo Setup
    Apr 2011
    Athens, Alabama
    Im really new to turbos... All I know is how they function. Is the z3 kit easy to replicate? If so ill just get the dp, crossover,and wastegate. All id need is advice on inlet piping and intercooler piping. And id probably just get ZZPs oil line kit
    Crashed 1997 GP GT Mods: Ebay Intake, SSAC Headers, 2.5" ZZP Catback, Poly Uppers, Polished Aluminum DB's, ZZP 1.0 PCM, 6000k HID's
    New Car: Black 2002 GT 4dr Stock
  1. Turbo setup
    By BoostnLSX in forum 5.3L V8 (LS4)
    Last Post: 01-31-2012, 06:12 PM
  2. Custom Carputer/HUD Setup
    By Confusingboat in forum Audio, Security & Visual Electronics
    Last Post: 06-12-2010, 03:45 PM
  3. Custom bolts/fasteners??? For IC setup
    By copgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2010, 12:24 PM
