Thread: L26 intake v.s. Blocked off supercharger
Results 1 to 9 of 9
  1. #1 L26 intake v.s. Blocked off supercharger
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Does anyone have any numbers saying which one is better? Has anyone ran either one and then switched to the other one and noticed a gain or lose?
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
    GT Level Member TurboKent's Avatar
    Woodward, OK
    never had the blocked supercharger but i do have the L26 and when i get all the programing kinks worked out it should run really well
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    Friend of mine is using the L26 UIM and a PnP L26 LIM to match his heads. The car is awesome, now I can't really comment on the pros vs. con of the Blocked off M90 Vs. an L26. But I can only assume it's better, I'm lookign at my ported L36 LIM right now and think about it.
    The Boost is filling the UIM and getting sucked into the cylinders like an N/A application, whereas the block off plate the boost is hitting the plate and be forced down, it must create way more turbulence in the intake.
    I think more people don't swap over because the injector bosses are in the L36/L26 LIM, but all you need to do is drill and tap them for a 3/8th pipe fitting and put one in there. All of 30 mins work.
    There are pros and cons to both, but overall on the street, the L26 would be better. A large, open plenum is good for an all-out drag car, the L26 helps spool and mid-range power...take your pick.
    i got one to sell if anyone wants it. candy purple powdercoated. from pector's old l36 build.
  6. #6 Re: L26 intake v.s. Blocked off supercharger
    I live here. UR LOSN's Avatar
    Rockford, IL
    intresting
  7. #7 Re: L26 intake v.s. Blocked off supercharger
    GT Level Member rodman's Avatar
    Apr 2008
    What about l32 long block with l26 uim and lim benn done does it even work....???
  8. #8 Re: L26 intake v.s. Blocked off supercharger
    Barksdale AFB, LA
    Quote Originally Posted by rodman View Post
    The bottom end of all Series II/III 3800s is more or less the same. It will work.
    2009 Subaru Impreza WRX STI
  9. #9 Re: L26 intake v.s. Blocked off supercharger
    Donating Users Reflective Concepts's Avatar
    Feb 2008
    Quote Originally Posted by Sabrewings View Post
    I concur. I put an L26 UIM on an L36 LIM on an L32 block and the fitment is all good.
  1. Make A 4" Fenderwell Intake (FWI)[*]
    By Street Wolf in forum How To Write-Ups/Tech Tips
    Last Post: 05-17-2019, 05:23 PM
  2. best air intake
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2008, 11:47 PM
