I took some pics of mine, but lost the cable to my camera.
Mines a K&N B035B4 filter, i can't find any info. on that #. It fits pretty good, but not sure what you would need since I have a PT61. I have 1 zip tie attached to the corner of the pcm and tightened so that it is wedged against the frame on the back of the headlight. It lays flat and hasn't moved, I have some header wrap on the wires close to turbo just in case.
Flange 3"
Bottom Outside Diameter 4.75"
Top Outside Diameter 3.5"
Top Style Rubber
Length 5.75"
Flange Length .75"
Flange Angle 0
Offset 0
Search here:
K&N Universal Round Tapered Cone Air Filters
This one is probably the same as mine: RU-5111 - K&N Universal Air Filters, Universal Rubber Filter
You would just have to measure your inlet on your turbo and make sure the 3" flange will fit on there.
