Thread: Turbo Build "UPDATED 12/22/2010"
Results 1 to 20 of 27
  1. #1 Turbo Build "UPDATED 12/22/2010"
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Here is the build so far:
    Z7 Crossover
    Z7 Downpipe with v-band
    Precision Turbo 6262
    Manual Boost Controller
    MVS Wastegate
    Z7 A2A IC w/ 50mm BOV
    Braided Fuel Lines
    65lb Injectors
    L26 UIM & LIM
    ZZP 304 Stainless Front Powerlog
    ZZP 304 Stainless rear Turbo Powerlog
    heres a few pictures:
    Im looking for some digrams that ive recently seen of the way they routed all the vacuum tubing to everything. Anybody have a link to that thread that knows what im talking about? Im going to be running an AEM boost gauge with that, where would that tee into as well?
    It was mentioned to me to make sure im not boosting the crankcase, exactly how do i know if i am or not?
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #2 Re: Turbo Build "Pics" and a few questions
    Greenville, SC
    Vacuums go as so:
    BOV- any vacuum behind the TB/ vent to atmosphere?
    Wastegate- vacuum on turbo housing
    Boost Gauge- anywhere on the IC piping
    "boosting the crankcase" is dealt with through valve cover breathers/ pcv breathers.
    idk if im missing something, im tired.
  3. #3 Re: Turbo Build "Pics" and a few questions
    Feb 2009
    flintnasty MI
    Quote Originally Posted by saleenprix View Post
    Vacuums go as so:
    correct
    wrong, goes on the engine vacuum.
    Wrong again, engine vacuum
    Wrong again, on L36/L67 motors, there is a fresh air draw in the throttle body that has to be blocked, on L26 intakes, the fresh air draw is on the top of the intake, and can be capped or left open.
  4. #4 Re: Turbo Build "Pics" and a few questions
    darkhorizon, what exactly did u do or i should say use to completely block off pcv on the uim?
  5. #5 Re: Turbo Build "Pics" and a few questions
    Feb 2009
    flintnasty MI
    Quote Originally Posted by bbptech View Post
    answered on cgp.
    I put a cap on the PCV valve nipple.
  6. #6 Re: Turbo Build "Pics" and a few questions
    Greenville, SC
    correct
    nipple on the turbo housing isnt engine vacuum..? IC piping isnt vacuum?
    My SRT4 has been running the vacs like that for years and everything works fine.
  7. #7 Re: Turbo Build "Pics" and a few questions
    Feb 2009
    flintnasty MI
    No, and the turbo housing is a lousy place to get boost reference from in my experience.
  8. #8 Re: Turbo Build "Pics" and a few questions
    Greenville, SC
    any turbo car ive ever worked on has the wastegate vacuum connect to that nipple. What do you mean by "lousy"?
  9. #9 Re: Turbo Build "Pics" and a few questions
    Topeka, KS
    You gonna put a blanket on that snail to help keep temps under the hood down ? Also as close as your radiator line is going to be to that turbo and exhaust it may not hurt to go braided on the rad lines because i could see that wearing or melting the rubber of the hose. Just my $0.02.
    PS Your setup looks very nice! I wish I would have went this route from the beginning.
  10. #10 Re: Turbo Build "Pics" and a few questions
    May 2008
    staten island,NY
    very nice upgrades compared to my Z7 kit. zzp did great with the v bands. you should have wrapped up the downpipe with heat wrap. as for the turbo blanket i bought mine from ptpturboblankets. i put a spark plug bootie over the coolant temp sensor because its so close to the crossover.
  11. #11 Re: Turbo Build "Pics" and a few questions
    I do plan to buy a turbo blanket for it. The upper radiator hose will be fine, I'm more so worried about the coolant temp sensor like mention above and the tranny harness under the turbo.
    It was mentioned to me by matt to not wrap the downpipe and crossover due to possible cracking.
    Thanks for the complements on the setup.
  12. #12 Re: Turbo Build "Pics" and a few questions
    Kansas
    Gonna be running 85 with that? IF so BADAZZ... Either way nice man, good luck, like ryno said.. I got a couple g's into my car I could of saved some more and got a turbo setup.
    Good luck with build
    SOLD 1999 GT Silvermist TS
  13. #13 Re: Turbo Build "Pics" and a few questions
    GT Level Member VictorSmalls's Avatar
    Dec 2008
    Tyrone, PA
    Nice build. Keep us posted with your progress.
    Retired
    Turbo'd
  14. #14 Re: Turbo Build "Pics" and a few questions
    Charles City, IA
    You change your mind more than john kerry. lol Looks awesome.
    SMGPFC Two Nipple General
  15. #15 Re: Turbo Build "Pics" and a few questions
    GT Level Member joshsGT's Avatar
    Nov 2009
    Marysville, MI
    Badass setup you've got going there so far man. I'm looking into going turbo instead of swapping an l67. Lookin forward to the end result and hearing your feedback.
  16. #16 Re: Turbo Build "Pics" and a few questions
    May 2008
    staten island,NY
    put the spark plug booty on the coolant sensor. the turbo blanket will protect the trans harness because it wraps around the whole side of the turbo. why would stainless steel crack? my downpipe is wrapped up nice. too much heat especially near the master and the throttle body
  17. #17 Re: Turbo Build "Pics" and a few questions
    Feb 2009
    flintnasty MI
    it sucks? I get turbulence?
    I tried it on my HX35 and it would not make less than 17psi, I moved it to the motor side and it made 13. In theory, it should make less boost sourced at the turbo, but something else decided against that.
    Simply put, nobody in the 3800 turbo world puts their wg reference there. I run my nitrous switch on that port, but thats it.
  18. #18 Re: Turbo Build "Pics" and a few questions
    Dude you have to let me check out your setup some time. Its nice to know that there are other GP owners from The Box on here.
  19. #19 Re: Turbo Build "Pics" and a few questions
    hahaha. Tha "Box". Shoot me a PM man. Im off tomorrow so we could meet up and ill let u check it out.
    To all the comments, Thank you. Finally took the leap. Wish i woulda done this quite awhile ago.
    Went ahead and wrapped all the pipes with header wrap and put a spark plug boot on the coolant temp sensor. Gonna be ordering my turbo timer and turbo blanket later on this week. And will be building a vac block throughout this week as well. more pics coming soon.
  20. #20 Re: Turbo Build "Pics" and a few questions
    Arizona
    mmm i love me a turbo gp!
    '00 GT- nothing special
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. Few turbo questions for the build!
    By 98GT3800 in forum Turbo
    Last Post: 08-13-2010, 08:42 PM
  3. 4t65e hd TRANS REBUILD ! " with pics "
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2010, 09:38 PM
