Thread: Maf freq
Results 1 to 4 of 4
  1. #1 Maf freq
    GT Level Member rodman's Avatar
    Apr 2008
    How do i know my maf is maxing out
  2. #2 Re: Maf freq
    Apr 2009
    Minnetonka, MN or Fargo
    from what i have read the GM MAF are pretty flexible at handling lots more air/colder air,if you were most likely you would throw a code that says you are running lean
    2007 GXP
    Wrapped crossover, Flipped motor mount, K&N W/headlight intake
  3. #3 Re: Maf freq
    Apr 2008
    no its not the stock one 4'' ls6 85mm plastic ..was ok for turbo but now intercooled ..the runs rich and sputters around 10,000 hz ...wondering if this is the issue
  4. #4 Re: Maf freq
    Donating Users Tengis's Avatar
    Houston
    Hz maxes at 15,000. You need to tune your car for the new MAF and you also need to tune for major changes (such as adding an intercooler). The air going over the maf element is going to be a different temperature so the readings will be completely different.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
