Thread: BOV
Results 1 to 7 of 7
  1. #1 BOV
    GT Level Member rodman's Avatar
    Apr 2008
    OK got intercooler installed....but car works like ****.....has to be bov issue....its tied into the map hose that feeds wastegate is that right....l26 upper intake...also boost gauge reads -30 at idle that can't be right...isn't it sopposto be at 0???
  2. #2 Re: BOV
    BOV...we dont have a blow off valve. We are not turbo'ed
  3. #3 Re: BOV
    TDCRacing
    Guest
    You have stepped into the turbo section
  4. #4 Re: BOV
    Quote Originally Posted by TDCRacing View Post
    Thanks...that means a lot to me *tear* LOL
    But I have never gone past 20 vacuum when Idling. If you are off that that make I would check for a vacuum leak.
  5. #5 Re: BOV
    Donating Users ROTTMAN's Avatar
    Feb 2009
    canada
    Quote Originally Posted by rodman View Post
    Well the -30 at idle is vacuum, not boost. Mine is -17 at idle and I really dont know what the normal range should be? Im sure someone here knows.
  6. #6 Re: BOV
    slc utah
    -30 vacuum thats a lot of suckage ha ha, is it turbo'd?
  7. #7 Re: BOV
    TDCRacing
    Guest
    Quote Originally Posted by gtpdude View Post
    You would also be in the turbo section just like the above user.
bov
