The turbo is tiny enough... Probably couldn't be capable of hurting the engine.
It would work, but you'd constantly be fixing things in the turbo kit itself and have to figure out a a lot of things on your own. Like a blockoff plate on the rear manifold or put the wastegate there on a open dump. Then a custom downpipe from the turbo and weld a flange on the crossover for the turbo. Then you would need a custom pcm... Then the fittings for the turbo oil lines... Then figure out the IC piping because thats just a bunch of pieces... Then weld in the BOV flange on the IC piping... Then pray to god there isn't more stuff you need to do and wait for something to break in a month... Then realize that the kit will probably cost over a $1000 when its put together the first time and you could get a IC or pay someone to throw a cam in your car for that price that might net you more power than this kit will hold.
