Thread: Turbo help
Results 1 to 7 of 7
  1. #1 Turbo help
    GT Level Member sdenton8's Avatar
    marshalltown, iowa
    I have a 07 grand prix 3.8 na. Im buying a used cartuning kit. Its the non intercooled version.
    My questions are....
    how much boost can i run on 91 octane gas?
    Im also thinking of adding meth injection
  2. #2 Re: Turbo help
    Kemmerer, Wyoming
    best answer is to scan for kr and when you see it, either reduce boost or pull timing. I ran water/methanol on my supercharged gtp and it works good. I went with the AEM kit. not a hard install, worked good, was progressive, just required filling the tank. maybe keep your eyes open for a cartuning intercooler kit, or build your own using ebay piping and air to air intercooler.
  3. #3 Re: Turbo help
    Banned
    May 2008
    VA (was NY, MI, MN, FL)
    I'll 2nd the intercooler upgrade. For ~$300 you can reliably and permanently lower your air temps and gain performance.
    I'd guess you'd be able to do 8-10psi non-I/C and up to 15-ish with I/C. Try to run the best octane you can (91-93, and non-ethanol premium when available... converting to E85 is possible out your way, but it's extra cost in a few ways).
    Good luck with the purchase, and keep us updated on progress.
  4. #4 Re: Turbo help
    May 2008
    Schuyler, NE
    Not much on 91. 7 or 8.
    And x2 on what everyone else said.
  5. #5 Re: Turbo help
    marshalltown, iowa
    With the meth injection take the place of the intercooler? The benefits of cooling the temp and higher octane it adds
  6. #6 Re: Turbo help
    Kemmerer, Wyoming
    it will help cool some, but not a lot.
  7. #7 Re: Turbo help
    Banned
    May 2008
    Quote Originally Posted by SgtMarshal View Post
    Correct, for the same basic cost, an intercooler setup will be more beneficial/consistent/no moving parts/etc. and still give you the freedom to add meth later, if you want to play with it down the road.
  1. Replies: 3
    Last Post: 08-09-2016, 08:12 PM
  2. Z3 Turbo Kit with New Turbo $2000 Shipped PRICE REDUCED
    By Swiggles in forum For Sale - Parts
    Last Post: 07-23-2016, 07:19 AM
  3. Replies: 23
    Last Post: 03-26-2014, 02:22 PM
