Thread: Need some insight on fuel pressure problems and 80# injectos
Results 1 to 2 of 2
  1. #1 Need some insight on fuel pressure problems and 80# injectos
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    I finished tuning my turbo build in the fall and I couldn't solve my cold start stall/rough idle issue. I was messing with it yesterday and noticed how fast my fuel pressure drops after prime, it goes to 40psi (which correct me if im wrong is low) to 0 in about 5 seconds. This is the first I have really messed with the Fuel Labs regulator and ZZP logs since I purchased them with the turbo kit. I'm not sure where I need to start exactly other than I already plan on replacing my stock pump with an AEM High Flow pump. But from what I've read the pump isn't usually what causes the loss of pressure just my total pressure amount. The pump im using now is only a couple years old replaced with an OEM ACDELCO pump and since then I have done the rewire kit. Is 40psi and adequate amount for 80# injectors? I am running 91+Meth, and could my loss of pressure be due from a bad regulator? or check valve? Any thoughts are appreciated as I am about to start throwing money at it.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  2. #2 Re: Need some insight on fuel pressure problems and 80# injectos
    Factory fuel system is only 3 bar (43.5 psi), so the prime being 40psi sounds just fine.
    If it won't hold pressure, then the regulator or if the pump has a check valve could be bad.
  1. Replies: 19
    Last Post: 10-20-2015, 09:22 PM
  2. Hi pressure low pressure fuel connectors , i lost the springs that go inside. help
    By Hardonyomom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2014, 09:31 PM
  3. RR tire pressure sensor problems
    By guyonsomecouch in forum General Tech Discussion
    Last Post: 12-18-2009, 11:30 PM
  4. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
