Thread: PCV system and going turbo
Results 1 to 7 of 7
  1. #1 Re: PCV system and going turbo
    Nov 2015
    Monroeville, Pa
    Why couldn't you just put a one way check valve to the throttle body so when under vac it works normally then under boost it blocks flow into crankcase?
    97 cavalier with L67 swap. F23 Getrag trans with stage 3+ SPEC clutch, KB pistons, L32 rods, LS6 valve springs, 3.4 pulley, ZZP downpipe 2.5, Full rotating assembly balance.
  2. #2 Re: PCV system and going turbo
    May 2008
    Schuyler, NE
    But you still need to vent the crankcase under boost, or it will find its own vent.
  1. Replies: 14
    Last Post: 09-29-2012, 06:45 AM
  2. 2004 Grand Prix GT. Service ABS System, and Taction Control System
    By Erika Schultz in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2012, 05:26 PM
  3. Turbo's System (56k warn)
    By 1LoudGrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 07-05-2009, 02:14 AM
