Thread: went back to the dyno and cant make over 15 psi?
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: went back to the dyno and cant make over 15 psi?
    hangover park IL
    only things I can figure are mechanical issues that prevent the Turbo from producing.
    a restriction Downstream of the turbine would be an issue....
    it sounds though like mostly you're dealing with the fact that HP tuners sucks ass with the new cars and since you don't have access to Tiny tuner you can't fix the rationality tables that are f****** you right now
    ~James~ Psychotic Gearhead
  2. #22 Re: went back to the dyno and cant make over 15 psi?
    GT Level Member rodman's Avatar
    Apr 2008
    No 3" stainless and off road pipe
  3. #23 Re: went back to the dyno and cant make over 15 psi?
    hangover park IL
    and if you don't have any pre turbine exhaust leaks or boost pipe leaks.....then is one of the PCM's nanny tables that the new DBW/04+ cars use
  1. Dyno Day $30 dyno pulls *now with FAIL* p3
    By danomite02 in forum Shows and Events
    Last Post: 10-01-2013, 04:44 PM
  2. e85 Dyno Tune at Dyno Tune Motorsports - Video
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2013, 07:57 AM
  3. ** Back from ZZP Trip - DYNO results **
    By Silver2kgtp in forum General Tech Discussion
    Last Post: 04-27-2011, 11:28 PM
  4. If if dont make money it dont make cents
    By CrAnK_DaT_SoUjA_BoI in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 01:00 AM
