Thread: Dyno time 584 rwhp. 6262 turbo ST1 cam
Results 1 to 18 of 18
  1. #1 Dyno time 584 rwhp. 6262 turbo ST1 cam
    SE Level Member SlowFiero's Avatar
    Feb 2008
    Canada
    Strapped the car down on the dyno today for some tuning, had some issues making my normal 28lbs of boost but still very happy with the results. This was on 25lbs of boost, pump gas with NOS brand octane boost, and iced intercooler. Mustang dyno, so dyno jet would be approximately 12% higher hp.
    Unfortunately tonight in trying to fix the boost issue, it over boosted, and blew the head gasket out.
    I'm going to take the car apart and sell off the turbo setup, gm racing transmission parts and/or transmission. Time to move on.
    Billet 6262 T3 turbo, PT1001 intercooler, ST1 cam, 140 springs, pushrods, N* TB, L26 upper, HV3, otherwise stock L32. 10.007 @ 135.54with 1.46 60' 3130 lbs
    Old GenV M90, XP, heads, N* TB, ST2 intercooler - 11.425@115.60 1.54 60'
  2. #2 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    GXP Level Member
    Mar 2015
    Tomball
    Nice numbers!
  3. #3 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Damn, good numbers. sorry to see about the head gasket. Did you just finish the build and now deciding to part out?
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  4. #4 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    Feb 2008
    Canada
    Been running a few years, was going to part it out end of this summer anyway. Wanted one more kick at running a 9, but it's not to be.
  5. #5 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    GTP Level Member
    Jan 2015
    Lincoln, NE
    what head gaskets were in it?
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  6. #6 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    Feb 2008
    Canada
    Stock head gaskets, 87000miles, heads had never been off. Other than cam, springs, pushrods etc, it was a bone stock engine.
  7. #7 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Holy **** thats impressive 28psi and never lifted a head with stock bolts. Im a lot less worried about turning mine up now
  8. #8 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    hangover park IL
    thats with the low lift ST1?
    we have the ST1R with .571 lift but the same 206/206
    ~James~ Psychotic Gearhead
  9. #9 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    Feb 2008
    Canada
    Yes standard ST1, .512 lift. Honestly was trying to break 600 on mustang dyno as goal, but it wouldn't make the last 3 lbs even with the solenoid at 100%, probably needed more waste gate spring. It picked up 100 hp from "street boost" of 15/16 lbs to the 25 on that run, would have been pretty close at 28lbs.
  10. #10 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    very nice!!!
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  11. #11 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    Nov 2012
    Erlanger, KY
    Great numbers... fix the head gasket!
    With the 6262, might have been pushing the limits of the thing? Crank wise, you were probably closing in on 700...
    Love to see ya fix head gaskets and slap a 6765 on that thing and rip some times well into the 9s...
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  12. #12 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    Feb 2008
    Canada
    It rattled pretty good before it popped. Didn't even have time to react. Guessing it was 35-40 psi, and lean since I didn't have fueling set for more than 28psi. Pretty sure rod bearings are probably hammered and ready to spin. The plan was to part out this fall anyway, so I'm just going to do it now. I've lost interest in the two seater over the last few years having wife and two kids, I'd like to move into a turbo Buick or grand national.
  13. #13 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    Feb 2008
    Canada
    Well while going through the garage looking at parts to sell and keep, I realized I had a set of used MLS head gaskets and a set of ARP head studs sitting there. Pulled the heads off and realized both heads had been lifted, and the front head gasket was about ready to fail as well. They were pushing combustion gasses out both inside and outside the engine. However both the heads and block looked good, so I cleaned everything up, put a coat of copper coat on the head and block and two coats on the head gasket as I assembled each side. Fired it up on the 23rd and went to a no-prep arm drop race at the airport on the 25th. Started at 15lbs and turned up slowly until last two passes at 26psi, no issues. Entered a cash days style race there and ended up top 5 out of 38 cars. Screwed up the launch and spun on my last pass, or it would have been a hell of a race.
    Here is video of first run a friend took, I didn't have the technique figured out to get the car to hook yet, and spun pretty bad.
    https://youtu.be/j931kmM2D-I
    Still a chance to get a 9 this year after all.
  14. #14 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    Antioch, IL
    excellent
    2009 Challenger SRT8
    Expert at being gay.
  15. #15 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    Kemmerer, Wyoming
    That's pretty awesome. What transmission are you using?
  16. #16 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    Feb 2008
    Canada
    4t65 with gm racing input, 1" chain, triple edge valve body input and 2nd clutch, z-pack 3rd. Precision billet cover non-lockup tq converter.
  17. #17 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    Buffalo
    Jesus dude... That's insane Glad you gave you gave it another go
  18. #18 Re: Dyno time 584 rwhp. 6262 turbo ST1 cam
    Nov 2012
    Erlanger, KY
    Good to hear
  1. First Time On the Dyno
    By shaneh17 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2015, 09:45 PM
  2. Dyno Numbers for the Turbo 04!
    By ADrugDealer in forum General Tech Discussion
    Last Post: 08-17-2014, 10:47 AM
  3. Dyno guessing time. Result: 266 WHP
    By matt5112 in forum Off Topic Discussion
    Last Post: 11-30-2011, 08:31 AM
  4. E85 Turbo'd GP hits the dyno!!
    By glanzergtx in forum General Tech Discussion
    Last Post: 08-07-2010, 06:38 PM
  5. 1HP Turbo Dyno Video
    By John02Hawk in forum Off Topic Discussion
    Last Post: 12-30-2007, 03:39 AM
