Thread: What's the most power someone has made on a pt61??
Results 1 to 20 of 21
  1. #1 What's the most power someone has made on a pt61??
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Last time I was on a dyno my car made 451 on 18 psi. Wondering if anyone knows if someone has made over 500?
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  2. #2 Re: What's the most power someone has made on a pt61??
    Kemmerer, Wyoming
    Not that I have anything useful to contribute, but I'm curious what the torque curve looked like on that dyno
  3. #3 Re: What's the most power someone has made on a pt61??
  4. #4 Re: What's the most power someone has made on a pt61??
    GTP Level Member
    Jan 2015
    Lincoln, NE
    It made 400 ft lbs. Probably had 300 by 3000rpm and made peak torque at 4600 4800 ish.
  5. #5 Re: What's the most power someone has made on a pt61??
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by fivefingerdeathpunch View Post
    hahahahahahahahahahahaha!
  6. #6 Re: What's the most power someone has made on a pt61??
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    What is your set up
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  7. #7 Re: What's the most power someone has made on a pt61??
    Kemmerer, Wyoming
    Quote Originally Posted by NebTurboST5 View Post
    Nice
  8. #8 Re: What's the most power someone has made on a pt61??
    GTP Level Member
    Jan 2015
    Lincoln, NE
    L32, st5, custom intercooler, cartuning hot side with some midifications. TEP trans, gmr chain, aramet 100 IS, PI 3000 stall billet converter etc. 3 inch exhaust from the steering rack back.
  9. #9 Re: What's the most power someone has made on a pt61??
    GTP Level Member
    Jan 2015
    Lincoln, NE
    It's only got 120 lb crow Springs shimmed to 130 lb seat pressure.
  10. #10 Re: What's the most power someone has made on a pt61??
    May 2008
    Schuyler, NE
    From what Matt has told me, you'd probably pick up some power by going to 150# springs.
  11. #11 Re: What's the most power someone has made on a pt61??
    GTP Level Member
    Jan 2015
    Lincoln, NE
    yeah i know. i think that im going to make it though this race season how it is now. im pretty sure that im floating the valves beyond 6000 as power starts to fall off pretty hard. either going to go to some 150# springs or pac 130# springs shimmed to 140# seat pressure.
    if i do though i need to pull the front cover and replace the double roller chain and have the crank gear machined properly...i never did that before.
  12. #12 Re: What's the most power someone has made on a pt61??
    Kemmerer, Wyoming
    I put in some crow cams 130's to go with the XP cam I have in, so I'm kind of in a quandary if I should change the cam and springs when I put the turbo on. it's not going to be a max effort build, I would probably be happy with 375.
    When I put the double roller in mine, I was going to have the camfer machined to match the stock gear, and sent the double roller gear with a oem gear to a member on here, he took some measurements and the double roller gear matched the oem gear really close, so no machining was done. It's possible that at some point Rollmaster changed the specs to match the oem specs, the only real evidence I have of this is the measurements that were taken by the member on here.
  13. #13 Re: What's the most power someone has made on a pt61??
    GTP Level Member
    Jan 2015
    Lincoln, NE
    i know mine is wrong becuase i measured the chamfer before i installed it. its out about 5 thousands. as to your build. i would not change the cam or the springs. it should make that kind of power on about 12-13 psi
  14. #14 Re: What's the most power someone has made on a pt61??
    Kemmerer, Wyoming
    I find it pretty funny that everyone says an XP cam is fine for a turbo, but when I emailed zzp last year about using an xp cam with a turbo, zoomer, the big dummy, said the xp cam was super laggy and made low hp with a turbo.
  15. #15 Re: What's the most power someone has made on a pt61??
    GTP Level Member
    Jan 2015
    Lincoln, NE
    is it the best choice? no. however it is perfectly adequate for your goals and plenty of people have made over 400hp on conservative boost.
  16. #16 Re: What's the most power someone has made on a pt61??
    Kemmerer, Wyoming
    I just started a thread with the same question on a facebook turbo page, and got this response: Keith Bauer On a stock l36 other then 1.9 rockers and ls6 springs on a open torque converter 17.5 pounds I made 448 wheel. I'm not able
    To close my torque converter but it makes a big difference to make a big number on dyno.
    edit: added more info on facebook group.
    https://www.facebook.com/groups/486639888019507/
  17. #17 Re: What's the most power someone has made on a pt61??
    GTP Level Member
    Jan 2015
    Lincoln, NE
    hmm...i dont know how to lock my converter on the dyno either.
  18. #18 Re: What's the most power someone has made on a pt61??
    GTP Level Member
    Jan 2015
    Lincoln, NE
    what is the part number for the pac 150# springs? i thought they were the 1219's but pac lists that as a 135# spring
  19. #19 Re: What's the most power someone has made on a pt61??
    May 2008
    Schuyler, NE
    1409x has a 175# rating at 1.8" install height. Zzp sells these as 150's.
    On my comp g that T.J. has now, I put 150# Manley's on that intense sells. That is what prj recommended to me at the time.
  20. #20 Re: What's the most power someone has made on a pt61??
    GTP Level Member
    Jan 2015
    Lincoln, NE
    thats interesting. the 1409x is not listed as a LS spring on Pac's website.
  1. I made this lol
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 03-07-2011, 04:52 AM
  2. How many were made?
    By wolfskin in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-28-2010, 03:21 AM
  3. I made it
    By offroadfury6 in forum Off Topic Discussion
    Last Post: 05-19-2009, 12:12 PM
  4. Made Some Changes
    Last Post: 12-31-2008, 08:42 PM
  5. I Made It!!!
    By x1FastGTPx in forum Introductions/Noob Questions
    Last Post: 01-12-2008, 07:47 PM
