Thread: Pulsing the turbocharger...
Results 1 to 20 of 61
  1. #1 Re: Pulsing the turbocharger...
    Jan 2016
    los angeles
    Quote Originally Posted by SgtMarshal View Post
    can you be more specific? not sure what you are asking
    It seems that this setup is running a turbocharger with a split hotside (divided housing) and according to my source a very large turbine housing and wheel. The engine still uses the stock converter which flashes around 2200-2400rpms. The point is I have not seen anyone running setup like this that pulse the turbine efficiently for a street car. So wanted to hear if anyone has seen a working setup on these engines are what are there thoughts
    Quote Originally Posted by Turbocharged400SBC
    That's just a funky dual wastegate setup. Usually when yer wg is undersized for the lower boost settings (high bypass/reducing drive pressure)
    Actually these are two functional waste gates used to control each bank of the turbine (housing)
    It is actually a 88 beretta GTU, with a 3800, not sure what type or version, but I am told it maybe a series3, getting a custom specific camshaft (no one knows much about the car...I am still digging)
  2. #2 Re: Pulsing the turbocharger...
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Quote Originally Posted by jbunla View Post
    I still have a ton of gtu/indy beretta stuff.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  1. Supercharger with a Turbocharger
    By MRinthePROgress in forum Engine
    Last Post: 02-23-2010, 06:44 PM
  2. Pulsing in 3rd
    By Dohner in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-26-2009, 08:37 AM
