Thread: Intake pipe/BOV questions...
Results 1 to 16 of 16
  1. #1 Intake pipe/BOV questions...
    Sep 2015
    Richfield
    I've decided to cross over to the dark side and go turbo. I will be using the Precision 6262 turbo, and plan on starting off with 8-9PSI. I'm
    going to be using my supercharger intercooler for now, until I have money for an air-to-air. ZZP claims that I don't have any need for a BOV running 10 or less PSI.....thoughts???
  2. #2 Re: Intake pipe/BOV questions...
    Kemmerer, Wyoming
    You should put a temp gauge in your lower intake manifold, might be good to see what kind of temps you have. I was going to do the same thing but decided selling the intercooler was better. You can put together an a2a ic for the turbo for like 350 with a little work
  3. #3 Re: Intake pipe/BOV questions...
    Sep 2015
    Richfield
    I've thought about pre and post temp sensors to see the temp drop across the core, great minds think alike! Any thoughts on the BOV that ZZP claims I don't need?
  4. #4 Re: Intake pipe/BOV questions...
    hangover park IL
    you don't need the blow off valve at the lower pressures but it will increase turbo life so just plan to add one
    ~James~ Psychotic Gearhead
  5. #5 Re: Intake pipe/BOV questions...
    Sep 2015
    Richfield
    Gotcha, thanks! Just figured I'd double check. Any recommendations on putting together a turbo outlet to throttle body pipe?
  6. #6 Re: Intake pipe/BOV questions...
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    When I first went turbo and with the CT kit, I keep my W2A IC since it worked so good when I had a 2.6 pulley on. It worked good while I had the P62 turbo. Once I went to the T67 I had to upgrade to A2A.
    With the P62 and W2A I couldn't go past 18lbs of boost
    CT offered a pipe that went from turbo outlet (cold) to the TB with a spot for a small BOV.
    See pics below. This was right after install was done. You can also see the hoses for the W2A IC
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  7. #7 Re: Intake pipe/BOV questions...
    Kemmerer, Wyoming
    Quote Originally Posted by Silver2kgtp View Post
    pictures are broken. I have an aeroforce air temp sensor kit and coolant sensor kit you could buy. both are new in the box. I was going to use them, but never got around to installing and now my intercooler is gone, so I have no need. you would just need an aeroforce gauge to use them.
    http://aeroforcetech.com/products_sensors_temp.html
  8. #8 Re: Intake pipe/BOV questions...
    Feb 2008
    NY
    should be fixed now
  9. #9 Re: Intake pipe/BOV questions...
    Feb 2008
    NY
    Chris,
    Clean you message inbox. Can't message you.
  10. #10 Re: Intake pipe/BOV questions...
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by SgtMarshal View Post
    a quality core is going to cost you almost 350 guy.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  11. #11 Re: Intake pipe/BOV questions...
    Kemmerer, Wyoming
    I'm looking at the treadstone tr8l, it's like 260
  12. #12 Re: Intake pipe/BOV questions...
    GTP Level Member
    Jan 2015
    Lincoln, NE
    little small but a good core. your gonna need 100+ dollars in couplers and clamps i would bet, piping, etc. i think when i did mine i spent about 800 to get everything the way i wanted and i didnt have to pay for the TIG welding work.
  13. #13 Re: Intake pipe/BOV questions...
    Kemmerer, Wyoming
    I found a guy on Facebook that sold his turbo kit, but still had the intercooler piping with all the clamps and couplers , got it for 100 bucks shipped. 2.5 inch, only thing it needs is a bov mount. There was another guy that out together a list of all the pipes needed so people can just look at the universal kits, and find one that had everything in the list. Or just go to cx racing and add each pipe individually.
  14. #14 Re: Intake pipe/BOV questions...
    Quincy, Mass
    Frozenboost.com I think has bov pipes so you can just added it in with couplers.
    No more GP 04 Impala SS Indy:
  15. #15 Re: Intake pipe/BOV questions...
    FrozenBoost is a great outlet for all that stuff.
    Honestly you can get a generic fleabay kit for $100~ or so and net all the couplers and piping you'll need to cut up and fab something.
  16. #16 Re: Intake pipe/BOV questions...
    Quincy, Mass
    That's what my future plan is, I already have a small Intercooler in the basement and I'll just make my piping kit
  1. 4" JMP or ZZP intake pipe
    By CrazyGuy03 in forum Wanted To Buy - Parts
    Last Post: 06-11-2015, 07:14 PM
  2. Intake pipe from a z3 turbo kit
    By Swiggles in forum Wanted To Buy - Parts
    Last Post: 06-01-2014, 08:26 AM
  3. intake questions
    By python1986 in forum Introductions/Noob Questions
    Last Post: 02-16-2013, 08:17 PM
  4. 08 Altima 3.5 CVT w/Intake,test pipe,& tune
    By pontiacman22 in forum Track Sessions and Kills
    Last Post: 10-20-2008, 03:51 PM
