Thread: L36 upper intake manifold
Results 1 to 16 of 16
  1. #1 L36 upper intake manifold
    Kemmerer, Wyoming
    I started installing my L36 upper intake manifold yesterday, and when I tried to hook up the vacuum line that connects the manifold to the brake booster, the L67 fuel rail got in the way. the angle of the barb was bad, so it would hit against the bottom of the fuel rail and not connect. I'm thinking an L36 fuel rail will fix the problem, but was wondering if you guys have any other suggestions. Is there a different barb I can use to get it connected?
  2. #2 Re: L36 upper intake manifold
    hangover park IL
    **** man your probably looking at cutting it and Jbquicking a threadin brass barb to come straight out or up.
    I know there are the early and late ones, early having the 1/4" nipple for the HVAC vacuum supply (non digital HVAC cars) but both had the hose at about 45*
    its a 3800...just rig it and we'll all dig it
    ~James~ Psychotic Gearhead
  3. #3 Re: L36 upper intake manifold
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    I took some pics of how my l26 upper is done albeit I have fuel logs on it now. It has a brass barb tapped and threaded into the port, comes out straight. Well my phone lost the pics I took, I will try to get some tomorrow again. Here is one of the outside of the intake, you can see the barb fitting sticking straight out of the manifold. HTH.
  4. #4 Re: L36 upper intake manifold
    Kemmerer, Wyoming
    Quote Originally Posted by Turbocharged400sbc View Post
    that's what I did. I cut the tabs off and stuck it in the hole at a different angle, and used copper rtv to seal it off. I left the o ring on and felt it lock into place when I pushed it in.
  5. #5 Re: L36 upper intake manifold
    Quincy, Mass
    You might need to get injector spacers. The l36 rail won't work unless you plug the injector holes on the l67 heads.
    No more GP 04 Impala SS Indy:
  6. #6 Re: L36 upper intake manifold
    Kemmerer, Wyoming
    I plugged the holes already. Used a 3/8 npt tap and some brass plugs. Also plugged the coolant holes and opened up the passage
  7. #7 Re: L36 upper intake manifold
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by SgtMarshal View Post
    I was gonna tinker on my turbo build tomorrow, and just realized that I hadn't thought too much about the injector holes on the in take. So, this is what you did? Tapped it with a 3/8 pipe tap and call it good?
  8. #8 Re: L36 upper intake manifold
    Antioch, IL
    tap or weld closed
    2009 Challenger SRT8
    Expert at being gay.
  9. #9 Re: L36 upper intake manifold
    Kansas City, MO
    Tap..........3/8? That's what I'm asking.
  10. #10 Re: L36 upper intake manifold
    Kemmerer, Wyoming
    3/8" tap. The welding expert said it would be a pain in the ass. Use a 37/64 or 9/16 drill to prep the holes.
    We used an impact to tap the holes so it wouldn't take 2 hours
  11. #11 Re: L36 upper intake manifold
    Kansas City, MO
    Awesome. Thanks Marshall.
  12. #12 Re: L36 upper intake manifold
    Kemmerer, Wyoming
    Another thing you could do if you are using an l67 fuel rail is drill a hole and tap it so you bolt the corner of the real down. L36 has one different mounting bolt
  13. #13 Re: L36 upper intake manifold
    Kansas City, MO
    I've got a set of PRJ rails that we will be using.
  14. #14 Re: L36 upper intake manifold
    Kemmerer, Wyoming
    Do you know if they will have enough clearance for the vacuum barb on the bottom of the upper intake manifold? The angle of the stock vacuum barb doesn't jive with the stock rails
  15. #15 Re: L36 upper intake manifold
    Kansas City, MO
    I should have mentioned, using an F-body intake setup, so I'm not sure what the clearances are. It's more of a winter tinker project so far, so who knows what we're gonna run into.
  16. #16 Re: L36 upper intake manifold
    Kemmerer, Wyoming
    Quote Originally Posted by Reptile View Post
    Oh, that's totally different
  1. Upper Intake Manifold Repalcement
    By GPCharlie in forum General Grand Prix Discussion
    Last Post: 04-09-2015, 11:45 AM
  2. upper intake and lower intake manifold gasket
    By RICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2014, 12:06 PM
  3. upper intake manifold?
    By Akuch26 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2012, 01:22 AM
  4. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
