Thread: Twin gtp e engines custom car runs 9.11
Results 1 to 20 of 25
  1. #1 Twin gtp e engines custom car runs 9.11
    GTP Level Member TwinV6GTP's Avatar
    May 2013
    Gatineau
    Yup trans are slipping bad, especially the rear since I can't turn down the power.
    Up front I limit the power to 20 psi of boost.
    9.11 @ 145 mph backing off before the end (out of gear on the rev limiter because of trans/torque converter slip).
    Easily an 8 second car if we can get the trans to hold the power. I can't lower power more at the back so I will have to put on a bigger wastegate.
    then with less slip and less power the car will go faster.
    Ran a 1.32 60 foot in practice, then tried a full pass for the 1st time. 9.11 @ 145mph.
    0-60 mph was recorded by GPS at 1.6 seconds !
    Car revs 6900rpm from start to finish the shift light never turns OFF !!! Talk about slip...
    The traction was really good making the problem even more obvious.
    2015 Custom Twin Engine Nascar style car with dual GTP 3.8 drivetrain, Front trans 4T65e-HD, Rear 4t80e trans 1/4 mile 8.38 @ 165mph
    2000 GP Twin Engine Twin TD Turbo kits. Stock engines stock trans(s) stock injectors stock MAFs 0-60mph 1.8 seconds 1/4 mile 9.72 @ 139 mph
  2. #2 Re: Twin gtp e engines custom car runs 9.11
    Panama City Beach, FL
    Neato. 'Grats.
  3. #3 Re: Twin gtp e engines custom car runs 9.11
    May 2013
    Gatineau
    Bonus vid, street testing !
  4. #4 Re: Twin gtp e engines custom car runs 9.11
    I break stuff selliott's Avatar
    Kansas City
    Anyone feel a draft? Lol awesome car!!
  5. #5 Re: Twin gtp e engines custom car runs 9.11
    ^Tee hee. Good one.
  6. #6 Re: Twin gtp e engines custom car runs 9.11
    May 2013
    Gatineau
    Quote Originally Posted by selliott View Post
    Thanks !
    Lots of work. We wll be putting the stock converter on the rear engine. The custom Precision one can't handle the power I'm making.
    I believe I can hit 8s easily with the stock converter there.
    There was a decent headwind and I backed off before the end. An 8 would have been possible even with all the problems with a few tries but no use putting the drivetrain through the stress when there is an obvious problem.
    Makes no sense to have to short shift to 4th before the 1/8 mile with 3.11 gears and 28" tall tires and 7000rpm redline
  7. #7 Re: Twin gtp e engines custom car runs 9.11
    Arizona
    I need your fab skills to make a ls4 turbo kit
  8. #8 Re: Twin gtp e engines custom car runs 9.11
    GT Level Member sugaryuk's Avatar
    vancouver,bc
    Too much power and the body fell off? Any plans of putting a shell on?
    02 GT- L32/Gen V, 3.3 mps, zz 1.9's, N*, slp front to back, OverKilled, 180 tstat, 104's, K&N cai, lowered with GMMP susp, 12" PBR brakes
    75 Pro-Street Vega-- Blown 383 stroker with Nos fogger system
  9. #9 Re: Twin gtp e engines custom car runs 9.11
    GT Level Member Hardonyomom's Avatar
    aurora
    Looks like a toy now, reminds me of my rc car with dual batteries on 6s power. Both cars are nuts. No i am not comparing your car to my my rc car. Your car is insane!!!
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  10. #10 Re: Twin gtp e engines custom car runs 9.11
    May 2013
    Gatineau
    This is the body that we designed the frame to fit in. But first, mechanically it has to be finalized.
  11. #11 Re: Twin gtp e engines custom car runs 9.11
    Jan 2014
    AR
    That ain't too shabby, looks better than a G8! I'm just amazed that theres a set of rules that will let the monster on a track someplace, and pleased to see the Pontiac torch sustained by folks who obviously have the arrowhead bug. Also pleased by the ET... the thing makes it look easy too. Too wild!
  12. #12 Re: Twin gtp e engines custom car runs 9.11
    May 2013
    Gatineau
    Thanks. The power is only 65% up front and lots of torque converter slippage on the rear setup that makes more power. Deep 8s are in the cards for sure.
    1.3 60 foot without any drama and barely any spin goes straight as an arrow. All the plannig design paid off.
    117" wheelbase and custom frame designed by myself. The whole car without drivetrain or drivetraon accessories weighs only 600lbs or so. And its very strong. We can lift any corner and get no noticeable flex unlike any modern unibody. The cage is a sportsman stock car style and the only part we didnt make.
  13. #13 Re: Twin gtp e engines custom car runs 9.11
    Arizona
    Bro you made it on 1320 video again
  14. #14 Re: Twin gtp e engines custom car runs 9.11
    GT Level Member jrb1027's Avatar
    Jun 2013
    brookville,IN
    This has been the coolest build I have ever seen, you guys build some really quality stuff its great to see you are following threw with it.
  15. #15 Re: Twin gtp e engines custom car runs 9.11
    gardner,mass
    Def looks kool but why g8? seeing its a 6 cyl I would of gone grand prix for sure just to prove a point to others.
    Edit: just realized they had a 6 cylinder base but still
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  16. #16 Re: Twin gtp e engines custom car runs 9.11
    Nov 2011
    NY
    Sub'd for awesomeness!!!
  17. #17 Re: Twin gtp e engines custom car runs 9.11
    May 2013
    Gatineau
    Quote Originally Posted by jrb1027 View Post
    Thanks...
    It now made speed society and also is now on Gas Monkey Garage facebook page.
    25000 shares and 45 000 likes in 24 hours and growing fast
  18. #18 Re: Twin gtp e engines custom car runs 9.11
    Kansas City
    farmtruck and azn posted your video on Facebook
  19. #19 Re: Twin gtp e engines custom car runs 9.11
    May 2013
    Gatineau
    Richard Rawling as well lol
  20. #20 Re: Twin gtp e engines custom car runs 9.11
    Mar 2012
    NC
    Quote Originally Posted by TwinV6GTP View Post
    That's because everyone appreciates awesome work. Wish I had all the cool toys to build things like you do so I could make it on there too. LOL
  1. 9 Second 1/4 mile runs this weekend with the Twin Engine GTP !
    By TwinV6GTP in forum Track Sessions and Kills
    Last Post: 08-29-2014, 11:22 PM
  2. Twin Engine GTP First runs at the dragstrip !
    Last Post: 08-08-2014, 09:53 PM
  3. 94 Olds 442 462ci-4wd-2 (twin) engines
    By turbocharged406sbc in forum Oldsmobile Cutlass
    Last Post: 07-10-2014, 05:52 PM
  4. Starts, runs fine for a week, then won't start for 5 minutes, then starts and runs...
    By Summit670 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2012, 05:33 PM
