Thread: Getting car ready for the track... Any suggestions?
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
  1. #1 Getting car ready for the track... Any suggestions?
    Jul 2014
    Virginia
    Finishing up the car and getting the final touches on it.
    I'm gonna run:
    zzp shortblock 9.9:1
    Gen 3 ported manifold and m90
    3.0" pulley
    full 2.5" zzp intercooler with fmhe and 39 GPM pump
    intense stage 2 cam with ls7 lifters
    105 springs shimmed to 110
    Rollmaster single roller (No plans to ever put a bigger cam in at this time, my mext move is a turbo)
    Pacesetter 1 3/4" primaries wrapped front rear and cross over
    built trans running 3.29 final
    7/8 chain
    42.5 injectors
    Straight tube to the fender with a monster conical filter
    Heads have been milled to .610 and ported. Stock valves. Modified retainers and new seals.
    My only concerns are when I let the put the car around 1500 and let it sit there for about 10 seconds it heats up RAPIDLY to the point where it approaches 210+ degrees
    also need to replace the snout gasket on the SC it has a small oil leak.
    How do I make the best pass possible, good launch RPM??? Will be on street tires and 93 octane any idea what time to expect?
    Zzp tune, thinking about possible meth injection for the pass because ill be running 93 or better depending on whatever is available at the track.
  2. #2 Re: Getting car ready for the track... Any suggestions?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    what do you mean when you put the car at 1500?
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  3. #3 Re: Getting car ready for the track... Any suggestions?
    Jul 2014
    Virginia
    Rpm, it was low on water I fixed that
  4. #4 Re: Getting car ready for the track... Any suggestions?
    Jul 2014
    Virginia
    Supercharger snout bolts were loose fixed that too
  5. #5 Re: Getting car ready for the track... Any suggestions?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    if the track is prepped well just rev it up and hammer on it. if they spin rev it up less. dont do a burnout on street tires. all they do is get slick and greasy. what cam is in the car? pretty hard to guess what its gonna run.
  6. #6 Re: Getting car ready for the track... Any suggestions?
    Jul 2014
    Virginia
    Sorry if it got lost in the list car is running an intense stage 2 cam. Its probably gonna run like ****. I have never floored the car at 0 even before all this! I don't think im a "skilled" driver. Thanks for the advice. Personally I dont care what it runs just really more looking for advice on how to run it!
  7. #7 Re: Getting car ready for the track... Any suggestions?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    i guess i dont know what a stage 2 cam is...have you ever had a scan gauge on the car or a tuner so you can see how it is running?
  8. #8 Re: Getting car ready for the track... Any suggestions?
    Jul 2014
    Virginia
    The stage two from intense racing, yes I have a scan gauge it broke im gonna buy a new one. Im unfamiliar with doing my owm tuning but open to it
  9. #9 Re: Getting car ready for the track... Any suggestions?
    Jul 2014
    Virginia
    http://intense-racing.com/PROD/CAM-67x.html
    the can is their stage 2 grind
  10. #10 Re: Getting car ready for the track... Any suggestions?
    Jul 2014
    Virginia
    Cam*
  11. #11 Re: Getting car ready for the track... Any suggestions?
    Which track are you running at?
    04 Comp G.
  12. #12 Re: Getting car ready for the track... Any suggestions?
    Banned
    Jan 2013
    maryland
    I'd say a 13.3 at 103 ...12.9 if you are a good driver if you have better tires probably in the high 12's
  13. #13 Re: Getting car ready for the track... Any suggestions?
    Jul 2014
    Virginia
    Quote Originally Posted by jayroca View Post
    Running at richmond or fredricksberg when I get a chance. I hope I do better than 13.3 or 12.9 with all the money ive got in it. I was hoping with high compression pistons theyd do me some justice. Ive poked around and seen guys on here with a hell of alot less running low 13's. I guess worst case I buy a turbo earlier than planned!
    Will post what I get for time when I do run it.
  14. #14 Re: Getting car ready for the track... Any suggestions?
    Sep 2014
    Worcester, MA
    is 93 Octane pump gas enough for 9.9comp with a 3.0 pulley?
    (I'm not trying to imply it isn't because who knows... but sounds risky to me)
    -BC
  15. #15 Re: Getting car ready for the track... Any suggestions?
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by GTPMidknight View Post
    Every car is different... Everything plays a factor in what ive learned at the track... Altitude...Tires... Weight.. Launch...Low expectations is the key: dont go to the track thinking you will run a 11's or low 12's and barely can get into low 13's .. your setup isnt sh*t , but i would lean to low 13's and
    High 12's to start
  16. #16 Re: Getting car ready for the track... Any suggestions?
    60' time is going to be a huge factor especially on street tires IMO.
    Should be able to crack some high 12s id think with the 3.29s as long as its got traction.
  17. #17 Re: Getting car ready for the track... Any suggestions?
    Jul 2014
    Virginia
    I really dont know brother. The guy at intense told me I was at the bleeding edge of what the injectors were capable of and id have to watch the scan guage while driving for KR and injector load and thats the only way to know if I need bigger ones.
  18. #18 Re: Getting car ready for the track... Any suggestions?
    Jul 2014
    Virginia
    I agree whole heartedly, was just throwing that out there I appreciate all the advice I can get. Is an investment in drag radials a smart idea? I have never floored the car even with just an intercooler and 3.0" pulley. I have done some e brake burnouts about 10 years ago when I was in high school.
    I'm not sure when the track is gonna open but I do want to go fully prepared to get the best time I can get for a first time racer. I wouldnt be surprised if I ran a 14 the first pass even on slicks. I have never even ridden in a car with more than 250-270 WHP Except a new 5.0 mustang one time.
  19. #19 Re: Getting car ready for the track... Any suggestions?
    Jul 2014
    Virginia
    I dont even know what to expect when I punch the gas! moderately nervous!
  20. #20 Re: Getting car ready for the track... Any suggestions?
    Jul 2014
    Virginia
    my biggest fears are breaking the car, wrecking the car, and *****ing out/ not knowing how to recovery if the tires go up in smoke.
  1. About ready to cry..PLEASE help
    By TJs97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2013, 09:13 PM
  2. Bio248's Track Ready Ferrari
    By blueguy in forum Members Rides
    Last Post: 10-20-2012, 10:37 PM
  3. Ready to go!
    By Schoop in forum Introductions/Noob Questions
    Last Post: 01-25-2011, 08:33 PM
  4. I'm ready to have some fun with a GP
    By Chmanzi in forum Introductions/Noob Questions
    Last Post: 11-25-2009, 11:18 PM
  5. Getting Ready. Any Last Suggestions???
    By kingbrentdwyer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-22-2009, 01:09 PM
