Thread: GXP vs a Comp G
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: GXP vs a Comp G
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    I'll say this about tap shift. In second gear it does hold the rpms until redline whereas in "D" it seems to shift a lot earlier. I'm not sure if that helps or hurts if more management software is essentially slowing things down in tap shift.
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  2. #22 Re: GXP vs a Comp G
    Arizona
    Quote Originally Posted by blueguy View Post
    Common sense > any thread.
    You can't shift faster than a computer, nor get the exact same shift points each time either.
    Only thing Tap Shift is good for is holding a gear when: roll racing or tracking the car.
    Tap shift does exactly that holds the gear as long ad I need it to do. It all depends on your cars setup. It has nothing to do with shift times its about keeping the power band and shift point where I want them instead of programmed logic doing the job. And if your car is tuned tap shift is a better solution then drive.
  3. #23 Re: GXP vs a Comp G
    Slower, Lower Delaware
    That's what I do, use it for holding a gear, then back into D.
  4. #24 Re: GXP vs a Comp G
    Quote Originally Posted by 91parkave View Post
    You get some black and white hard evidence on paper...such as...quicker times at the drag strip.
    I already admitted to it being worthwhile if you autocross the car...I'm just willing to bet you can't go really any faster in the quarter with it, that's all.
  5. #25 Re: GXP vs a Comp G
    My car had a canned tune and in D shifts at 6000 every time. Shutoff is set at 6200. With Tap shift I couldn't do any better.
  6. #26 Re: GXP vs a Comp G
    Arizona
    Look back at my post on page 1 half way down
  7. #27 Re: GXP vs a Comp G
    Arizona
    Quote Originally Posted by Sudden View Post
    Thats because youre tune didnt up the shift MPH to get that extra RPM you were looking for, thats not a tapshift issue, that is a tune issue.
  8. #28 Re: GXP vs a Comp G
    That's what I meant. But the PCM raised the shift from 5800 to 6000, and it does it every time without me having to do it. It never made it to 6000 with the stock PCM. And that is what I was looking for. I do use the tapshift to drop into the right gear for a rolling race.
  9. #29 Re: GXP vs a Comp G
    3800 =/= to LS4.
    Shouldn't be revving a stock valvetrained 3800 to 6 grand anyways
  10. #30 Re: GXP vs a Comp G
    3800 =/= to LS4.
    Wheres the thread of the guy who did that, race gas, meth, exhaust, and ran great times?
  11. #31 Re: GXP vs a Comp G
    Arizona
    3800 =/= to LS4.
    Or for that matter a ls4 dod lifters are bad enough as is.
  12. #32 Re: GXP vs a Comp G
    Oct 2012
    Nowhere NY
    Mine did not run any better with tapshift at the 1/8th mile, and mine is tuned. I think its only beneficial in a roll race/autocross and if you know what your doing, from a dig i think its pointless to make a difference
    Ive been medicating with burnouts and alcohol
  13. #33 Re: GXP vs a Comp G
    Arizona
    OK let's acknowledge on a factory cal or unless its been set in your Tue that tap shift will be the around the same as stock. Minus just being able to hold the gears to your liking. If your tune specifiacly addresses all of the pattern y tap shift tables then it will keep shifting as It always was. Which is why you won't notice a difference when in tap shift
  14. #34 Re: GXP vs a Comp G
    Apr 2013
    Macomb Mi
    Hey logic I'm from Detroit area can I get in?
  15. #35 Re: GXP vs a Comp G
    Jul 2012
    Chicago
    I remember as a kid when I got super excited over the TapShift thing... Then I realized... 4 steep ass gears. Teh Failz
    -Carl
  16. #36 Re: GXP vs a Comp G
    Jul 2010
    Detroit
    Of course pm me your info and I'll get you the details.
    Ryan
  1. My 04 Comp G
    By rodguezsciii in forum Introductions/Noob Questions
    Last Post: 03-16-2013, 03:19 PM
  2. L32 to L67 in 04 comp g
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2013, 08:16 AM
  3. 04 Comp G here i come
    By Timing in forum General Grand Prix Discussion
    Last Post: 08-09-2012, 10:26 AM
  4. Comp G trans in a non Comp G
    By Explicit_Spade in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2011, 10:31 PM
  5. Why do most of you think the Comp G is better than the GXP
    By Panther427 in forum General Tech Discussion
    Last Post: 01-01-2009, 03:17 PM
