Thread: dyno tune disaster
Results 1 to 20 of 28
  1. #1 Re: dyno tune disaster
    SE Level Member 707chance's Avatar
    Fredericksburg Va
    There is a folder in the HPTuners editor called Transmission Diagnostics where you can find a few parameters that restrict gear command. Our STOCK numbers are set at 5500 rpm and 62 mph. The rpm and mph must be UNDER these two parameters to enable gear control. MY current modified file on the car is set at 6200 rpm and 188 mph. Looking at my scan, the mph was at 145 mph, below the 188 requirement, and rpm was at 6050 which is under the 6200 rpm requirement which will allow gear command. This explains not only how it is possible to occur but why guys with stock trans tunes or just ratio changes cannot command a downshift when going over a certain speed.
    The TC used in my transmission package is not designed to be locked during WOT. The TC was locked during the dyno testing and could have been damaged. Debris could of then of been throw back into the transmission.
    2006 GXP almost done! I/H/C/E, TEPw/3.29s, small shot
  2. #2 Re: dyno tune disaster
    Stop me if I'm being a pain, because that's not the intention at all. RPM limiter wea removed?
  3. #3 Re: dyno tune disaster
    Fredericksburg Va
    the parameters were changed that allowed the car to be downshifted in manual mode...so I would have to say not remove but changed
  1. dyno and tune shops
    By Tuned07GPGT in forum Introductions/Noob Questions
    Last Post: 08-23-2010, 12:05 AM
  2. New Dyno Tune Numbers
    By josh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2010, 04:27 PM
  3. Dyno/tune day Northern Cali
    By TorqueAutoMotiv in forum West
    Last Post: 09-23-2009, 10:06 PM
  4. anyone get a dyno tune from ZZP?
    By Liquifire in forum General Tech Discussion
    Last Post: 07-17-2009, 04:53 PM
  5. My Dyno Tune
    By Keifer in forum General Tech Discussion
    Last Post: 07-15-2008, 07:12 AM
