Thread: Manufacturing tolerances in wheels
Results 1 to 6 of 6
  1. #1 Manufacturing tolerances in wheels
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I had a thought today, knowing how many people run 5x114.3 and how many run 5x115. I was wondering if anyone knew of the allowable tolerances in the bolt patterns of wheels (if any). IE like say a 5x115 wheel could have like +/- 1mm ect or less. Only crossed my mind seeing really how small of a difference between the 2 patterns is because its only .7mm and that maybe that could actually be less than a manufacturing tolerance or maybe more. I literally have no idea what it could be so here I am seeing if anyone has any other information on the topic.
    2012 F150 STX
    - Gonna be a race truck
  2. #2 Re: Manufacturing tolerances in wheels
    Other info..
    Toyota rims fit on Chevy pickups..but the damn lug holes are huge..
  3. #3 Re: Manufacturing tolerances in wheels
    Nissan rims fit of silverado's too.
  4. #4 Re: Manufacturing tolerances in wheels
    GT Level Member mguzzo's Avatar
    Buffalo NY
    from a design point of view you'd have to see the specifications for both the castings and the machined rim. Typically, the design would call for the true position of the holes to be cast at a fairly tight tolerance (probably in the +/- .010" range) at maximum material condition to provide the most "meat" for machining and stay steel safe. The machining operations to clean up the holes, if needed, would probably be in the +/- .005" range.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  5. #5 Re: Manufacturing tolerances in wheels
    SWPA
    The .7mm would actually be divided in half so there is really only a difference of .35mm per hole. That is around 1/100 of an inch.
  6. #6 Re: Manufacturing tolerances in wheels
    bolt patterns like 5x120/5x120.65, 5x115/5x114.3 are readily interchangeable (i'm running 5x120 wheels on my 5x120.65 hubs), but anything beyond that is a no go. you can us wobble bolts on something like a 5x110 to 5x112, but it's typically not recommended.
    then you have to start looking into hub bore sizes, offsets, brake caliper clearance, etc. etc.
    there's a lot to know about wheels besides just the bolt pattern and the diameter/width.
  1. shaking steering wheel after wheel bearing replacement
    By vandezand in forum General Tech Discussion
    Last Post: 05-14-2014, 04:02 PM
  2. Passenger wheel and wheel area hot and smeels of hot metal
    By TheInterloper in forum General Tech Discussion
    Last Post: 02-11-2014, 11:59 AM
  3. Wheel rocking still... already changed wheel bearing. Ideas?
    By jmn in forum Introductions/Noob Questions
    Last Post: 09-30-2013, 09:27 AM
  4. Got some wheel questions for you wheel guys
    By gtpeddie in forum Tires & Wheels
    Last Post: 09-22-2013, 07:07 PM
  5. Front wheel squeeks when wheel is straight.
    By chevyy1212 in forum General Tech Discussion
    Last Post: 06-13-2011, 07:02 PM
