Thread: These are cheap.. I really need tires..
Results 1 to 10 of 10
  1. #1 These are cheap.. I really need tires..
    GT Level Member m17davis's Avatar
    Orland Park, IL
    Hey guys. I plan on rims in future. But my tires are completely bald. I found these on Craigslist.http://chicago.craigslist.org/wcl/pts/5163298098.html
    I plan on getting 18x9 245/45/18
    But I need something asap. Will these do?
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: These are cheap.. I really need tires..
    Why do they look like someone sprayed tire foam all over them? They seem to be a bit too small.
    http://www.grandprixforums.net/threa...stions-In-here!!
    Tire sizing
    The stock tire size is 225/60/16. Here are the sizes for wheels that have the same overall diameter and that are most typical for people to run:
    235/55/17
    245/50/17
    235/50/18
    245/45/18
    235/45/19
    245/40/19
    245/40/20
    245/35/20
  3. #3 Re: These are cheap.. I really need tires..
    you need to find out what the hub bore is on the wheels. if larger then 70.3 you need hub ring spacers, if they are smaller then the 70.3 they wont work at all.
    hub rings are cheap, like 10 for the set of 4. you can get them off ebay.
  4. #4 Re: These are cheap.. I really need tires..
    Even if the rims fit the tires are still too small.
  5. #5 Re: These are cheap.. I really need tires..
    GXP Level Member
    Mar 2015
    Tomball
    Those would be about the same overall diameter as a 225-50 17 wouldn't it?
  6. #6 Re: These are cheap.. I really need tires..
    Orland Park, IL
    2 wheels 19x9.5 +20mm
    2 wheels 19x8.5 +15mm
    Will they fit if fenders get rolled
  7. #7 Re: These are cheap.. I really need tires..
    No idea.
    Sent from A Galaxy Far Far Away
  8. #8 Re: These are cheap.. I really need tires..
    Orland Park, IL
    Never mind those are 5x120. Dammit
    What's the max width I can fit with offset? I'm on coilovers
  9. #9 Re: These are cheap.. I really need tires..
    SWPA
    Quote Originally Posted by J57ltr View Post
    225/50/17 is too small too. 225/55/17 is the proper size there.
    225/40/18 is only 25.09" tall. Stock tire height is around 26.7".
  10. #10 Re: These are cheap.. I really need tires..
    GXP Level Member
    Mar 2015
    Tomball
    Well I'm running them since that's what the car had them when I bought it and I just replaced them, so until they wear out I'm going to run them (3.4" pulley to boot, hope I don't run into anything else). I know I'm about 2mph off at 65, so I'm racking up more miles than I should. When I get a tuner I'll change that, but for now I'm just going to run them.
    Jeff
  1. Replace 15" tires with 16" tires
    By maxim08 in forum Tires & Wheels
    Last Post: 10-24-2009, 06:44 PM
