Thread: Size 18 rims 2005 gtp how tall/wide can i go?
Results 1 to 15 of 15
  1. #1 Size 18 rims 2005 gtp how tall/wide can i go?
    SE Level Member James8026's Avatar
    Feb 2015
    Michigan
    I have 18's on my 2005 grand prix and i want to put as much rubber between rim and road as possible without rubbing when i turn or hit bumps.
  2. #2 Re: Size 18 rims 2005 gtp how tall/wide can i go?
  3. #3 Re: Size 18 rims 2005 gtp how tall/wide can i go?
    Feb 2015
    Michigan
    18x8
    Sent from my DROID X2 using Tapatalk 2
  4. #4 Re: Size 18 rims 2005 gtp how tall/wide can i go?
    SWPA
    Run 245/45/18. You don't want taller tires than stock for several reasons.
  5. #5 Re: Size 18 rims 2005 gtp how tall/wide can i go?
    Feb 2015
    Michigan
    Had 235/ 40. But that left me with a bent rim :-/ but it was repairable for $100 michigan roads are harsh
  6. #6 Re: Size 18 rims 2005 gtp how tall/wide can i go?
    Feb 2015
    Michigan
    Not even a little bit like 245/ 50?
  7. #7 Re: Size 18 rims 2005 gtp how tall/wide can i go?
    I'm sure you could sqeeze a 255/40/18in there if they even made a tire that size that was cheap enough, but like said a 245/45 best suits that rim size.
  8. #8 Re: Size 18 rims 2005 gtp how tall/wide can i go?
    Feb 2015
    Michigan
    Gotcha thanks
  9. #9 Re: Size 18 rims 2005 gtp how tall/wide can i go?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    i am currently running 245/45/18's and have about 3/4 inch clearance to the strut in both directions. the overall tire hight is 26.1 inches. you could probably get away with a 255 or 265/45 but it would be tight. 8.5 inch wide rim
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  10. #10 Re: Size 18 rims 2005 gtp how tall/wide can i go?
    Feb 2015
    Michigan
    Anyone ever rebuilt one of these m90 superchargers? Is it hard/ time consuming or pretty simple and straight forward? Also want to put a smaller pulley on supercharger any idea where to buy one or what style i should use?
  11. #11 Re: Size 18 rims 2005 gtp how tall/wide can i go?
    SWPA
    Quote Originally Posted by James8026 View Post
    Because 235/40 is way too short. It's only 25.4" tall, where 245/45/18 is 26.68" tall, and that is the height you want to stick with.
    As for your question on rebuilding the supercharger... why do you think it needs rebuilt?
    As for your question on the pulley swap, you have much reading to do. I don't have the thread at hand, but you need to read the "safely modding your 3800" thread.
  12. #12 Re: Size 18 rims 2005 gtp how tall/wide can i go?
    Feb 2015
    Michigan
    No reason im pretty inclined i just like everything to be new and smooth if it can. it has 126000 miles not sure how bad interior parts wear in them. Also ive heard to use the 3.4l performance pulley
  13. #13 Re: Size 18 rims 2005 gtp how tall/wide can i go?
    SWPA
    You can't just slap a pulley on and call it good.
    As for the interior of the supercharger they are good to go. Only thing you might have to change is the coupler, and that is only if it sounds like rocks rattling at idle.
  14. #14 Re: Size 18 rims 2005 gtp how tall/wide can i go?
    Sep 2014
    Grand Rapids, MI
    I run 235/50/18, it's only slightly taller than stock and will give you more sidewall protection. Not to mention they're usually cheaper than 245's
  15. #15 Re: Size 18 rims 2005 gtp how tall/wide can i go?
    Donating Users timboku's Avatar
    Montgomery, IL
    Read this first.
    Safely Modding Your 3800 Powered Car!!
    http://www.grandprixforums.net/showthread.php?t=17482
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  1. What size rims?
    By smjohnson06 in forum Tires & Wheels
    Last Post: 02-04-2011, 12:35 AM
  2. gtx rims what tire size to go with?
    By stanggreg90 in forum Tires & Wheels
    Last Post: 02-25-2010, 11:03 PM
  3. What size rims?
    By ItZ MiKe 718 in forum Tires & Wheels
    Last Post: 01-04-2010, 03:15 AM
  4. If i was to get 20" rims how wide would you recomend with out rub?
    By MattTheBaker123 in forum Tires & Wheels
    Last Post: 10-24-2009, 06:07 PM
  5. WIDE tires and rims
    By scoobyydooooooo in forum Tires & Wheels
    Last Post: 03-26-2008, 01:21 PM
