Thread: Will corvette rims fit 04 GP?
Results 1 to 15 of 15
  1. #1 Will corvette rims fit 04 GP?
    SE Level Member Ballen's Avatar
    Nov 2014
    Michigan
    I want to put some chrome 19" vette rims like these on my 2004 GP I plan on buying the lug adapters but I am unsure if the width would fit.. any ideas? also does brembo or wilwood make calipers that will fit the car?
    Will corvette rims fit 04 GP? Attached Images
  2. #2 Re: Will corvette rims fit 04 GP?
    considering they're 18x8.5 (or 18x10) and 19x10 (or 19x12) (OR 20x12!) with really high offsets....hell no.
  3. #3 Re: Will corvette rims fit 04 GP?
    Kemmerer, Wyoming
    the bolt pattern is different
  4. #4 Re: Will corvette rims fit 04 GP?
    Nov 2012
    Madison
    He said the R word....ban him
  5. #5 Re: Will corvette rims fit 04 GP?
    SWPA
    This
    Quote Originally Posted by SgtMarshal View Post
    And this
  6. #6 Re: Will corvette rims fit 04 GP?
    you all didn't read. he said he would use adapters.
    but in the end that'd only compound the problem of them not fitting.
  7. #7 Re: Will corvette rims fit 04 GP?
    To the OP some regal dude had gunmetal C5 Z06 wheels on a black regal gs for years let me see if I can dig up some pics.
    Compond the problem how Ohhh MrWheelGod????
    seems to me this has already been done let me chase down some pics and yes of course the Z06 wheels on the Regal used adapters.....
  8. #8 Re: Will corvette rims fit 04 GP?
    you know he posted ZR1 wheels, right? you're talking about dean's regal that had some skinny vette wheels on it.
    once again, chasing me around trying to prove me wrong when you can't. learn to read.
  9. #9 Re: Will corvette rims fit 04 GP?
    Zr1 wheels are skinny on the front guy and the OP hasnt listed how wide of wheels, just the ZR1 style. Do you have any clue how many OE replica companies make ZR1 look a likes????
    Seems to me YOUR the one that doesnt pay attention and needs to RRRRRREEEEEEAAAAADDDDD!!!
    http://s13.photobucket.com/user/dean...all-1.jpg.html#!
    theres the pic i was looking for Bio found it.
  10. #10 Re: Will corvette rims fit 04 GP?
    the 18x8.5 wheels have a +56mm offset.
    with a bolt on adapter of a MINIMUM of 15mm (which would require to shave the stock studs down) it would give you a wheel with 18x8.5 +41mm. will that fit with a normal tire? you betcha.
    even with a bolt on adapter of 25mm (might not have to shave stock studs down) it would give you a 18x8.5 +31mm which is starting to push it for a 'normal' fitment.
    if that was the case i'd say go for it, but the MINIMUM size of a 19" ZR1 wheel is 19x10, which will absolutely not fit with an adapter no matter what you want to do. MOVE ALONG.
  11. #11 Re: Will corvette rims fit 04 GP?
    What if I cut my fenders and add some flares?
  12. #12 Re: Will corvette rims fit 04 GP?
    Dec 2010
    DMV
    Quote Originally Posted by dRunK13 View Post
    Then of course it will fit
  13. #13 Re: Will corvette rims fit 04 GP?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    As far as the lug pattern problem, perhaps it would be a better route to use an aftermarket hub with the correct lug pattern, or slots for multiple lug patterns, if such a thing is available on our platform.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  14. #14 Re: Will corvette rims fit 04 GP?
    the real way to go about this is to use the STYLE of the ZR1 wheel and find an aftermarket version of it in the correct size and bolt pattern for the car.
    however, that wasn't brought up anywhere in here.
  15. #15 Re: Will corvette rims fit 04 GP?
    Because doing things right doesn't happen in the WBody community.
  1. Corvette rims on 2008 grand prix.
    By mgborgo1575 in forum General Grand Prix Discussion
    Last Post: 08-27-2013, 11:36 AM
  2. Corvette Rims
    By Mad GTP in forum Tires & Wheels
    Last Post: 02-17-2012, 08:58 PM
  3. corvette or camero rims ?
    By bayareagtp in forum Tires & Wheels
    Last Post: 01-15-2008, 11:44 AM
